Mavic Pro
942 6 2018-8-29
Atlas_Aus
Thailand
Hi all,
Just started out in last couple of weeks with mvic air, but last week was given mavic pro to play with also... Very different... Anyway tonight I was loooking at some Pro videos and some had the plastic bubble over the gimble, others didn't. There is also a rubber cap I assume goes under the plastic bubble for storage.
Could you please confirm which is corect.
TIA
2018-8-29
Chasing Light & Shadows
Flight distance : 221476 ft
Don't fly it with the "plastic bubble" it's just a gimbal and camera protector, it'll fly with it but the picture quality will be bad and restricts air flow.
2018-8-29
DJI Paladin
Flight distance : 318 ft
Thank you for reaching DJI forum. Leaving the Gimbal Cover on during flight isn’t necessarily a mistake, depending on what you want to do. Leaving the cover on during flight will make sure your Mavic’s gimbal camera is protected from the elements, such as dust or water. It will give you an extra level of protection if you’re concerned about something hitting it. So if you just plan on exploring your area or zooming around (safely) in Sport mode, you can leave it on. It won’t affect gimbal or flight performance.But, if you want the best image quality, possible, it’s a good idea to remove the cover. For example, leaving the Gimbal Cover on makes it more likely that you’ll get lens flare, and your shots may not look clean if the cover is dirty.
2018-8-29
Far_North
Flight distance : 278379 ft
Chasing Light & Shadows Posted at 2018-8-29 07:50
Your correct in that the gimbal bubble reduces image and video quality but it is perfectly OK to fly with the gimbal bubble on if that is the operators preference.  It will not cause over heating or any other negative performance issues other than image quality.
2018-8-29
Lonesome Crow
Flight distance : 408606 ft
I would not fly with it on.  Blocks the vents for the air to get inside of the electronics.
2018-8-29
Atlas_Aus
Thailand
Thanks all for the feedback... I have been flying without it on, was just curious as I did notice on in some tutorial videos.
2018-8-29
DJI Tony
Atlas_Aus Posted at 2018-8-29 21:46
Please keep us posted in any case you have other concerns. Thank you for the support.
2018-8-30
