Which model for photogrammetry?
2715 4 2018-8-29
TravisBanger
Hello,
I am involved with a project to perform ground laser scanner and aerial photogrametry. The subject is a famous, historical location: Dealey Plaza in Dallas.
Being a total newbie, my first question is this: Which model is best for professional level photogrammetry?
Thanks,
-Ramon F Herrera
JFK Numbers
2018-8-29
El Kab0ng
Flight distance : 156499 ft
I'd think something with the highest resolution possible.  If you're not versed enough to fly something like an Inspire 1/2, I'd go with a Phantom 4.  That'll give you the gimbal movement you need to capture the images you need in order to create the final product.  You could get away with a Mavic Pro, but You might have to fly sideways a lot, and that's not it's best flight direction.
2018-9-14
Frankndem
Mexico
El Kab0ng Posted at 2018-9-14 13:11
Hello; I am new to this forum, and seems I am not able to open a new thread, so I took the chance in this, hoping someone can answer my related question.
My company has a Mavic 2 Drone (not Pro, just plain 2), is it possible to do photogrammetry with it? I already tried DroneDeploy and Pix4D, but the drone is not detected by neither application. Is it because no app supports Mavic 2?
Have seen tutorials with 2 Pro, but not "Mavic 2" withouth the "pro". Is that a reason, the 2 is not good for photogrammetry?
Thanks in advance.
2019-7-24
Billboyheritagesurvey
Flight distance : 232306 ft
The resolution on the Pro 2 camera is probably the best for the money and certainly outstrips the earlier version.
So far I have had good mapping results with the MP2 :
https://billboyheritagesurvey.wordpress.com/2018/12/06/l1d-20c-image-quality-1st-thoughts/
https://billboyheritagesurvey.wo ... mavic-pro-2-gsd8mm/
https://billboyheritagesurvey.wordpress.com/2019/05/04/mavic2p-gsd-map-scale/
https://billboyheritagesurvey.wordpress.com/2019/05/21/mp2-swath-size/
https://billboyheritagesurvey.wordpress.com/2018/12/18/l1d-20c-at-50m-agl/
Good convergent coverage in appropriate lighting mixed with terrestrial coverage should work well.
I have tried to use frames sequentially split from video with mixed results: the frame reso is not as good taking stills.
B
2019-8-7
DJI Tony
Hi, thanks for the inquiry. We're sure that our valued DJI forum members would provide the best recommendation that you may need in regards to this query. Thank you for your support.
2019-8-7
