H3-3D Gimbal Issue Phantom 2
1013 5 2015-5-28
Josh S
My unit has not been crashed and in perfect working order.  Just recently the gimbal has started to act up.  When powered on it continues to stutter and jerk every few seconds.  Primarily pulling to the left and not returning to center.  I've included a couple videos in hopes someone might shed some light as how to go about fixing the problem.
http://youtu.be/ftf6YQ07OaQ
http://youtu.be/HiV9BZClXh4
http://youtu.be/VC13aE8RC_4
2015-5-28
Raybro
Flight distance : 11099 ft
Have you calibrated the RC with the assistant software. You may want to do a manual calibration, then use the assistant and do it there as well.
2015-5-28
away-point
Have you confirmed all related firmwares are up to day?
2015-5-28
Josh S
Raybro Posted at 2015-5-29 09:43
Have you calibrated the RC with the assistant software. You may want to do a manual calibration, the ...
Raybro, thank you for replying to my post.  I did in fact run a calibration as well as reinstalled firmware for the gimbal.
2015-5-29
Raybro
Not sure, bad motor, bad cable?
2015-5-29
Josh S
Raybro Posted at 2015-5-29 19:25
Changed cables.  Tried performing a hard reset but unable to get the LED to change from red, ...no amber or green.  Gimbal responds to the RC and will tilt up and down on command.  Just can't get it to stop jerking around every few seconds.
2015-5-29
