spyros.rho Posted at 2018-8-31 01:14
The SD card is different from the one I used when the problem first occurred (before sending it in), so it happened on 2 different cards for now. I use the card on windows only , and only for the Mavic (so I only transfer the files from the card to the PC). The card was new when I started using it. I can give it a try and format the card and see if that helps. Not sure of the manufacturer of the current card is atm, as I don't have the drone nearby I can't check. I believe it is a 64GB Sony. Will let you know. The first card was a 16GB SanDisk.
This could be related to the Micro SD card, did you try the stock SD card included in the package when you purchased it? Looking forward to your update. |
