Vins
Vins Posted at 2018-9-5 02:44
Thanks for the info. I activated my REs and upgraded the firmware to .600. I was able to connect them to the 2 Zoom and see through the camera. As a nube, I do have a couple of questions. I find that while I can see with the goggles, the gimbal doesn't follow my head movement. I fiddled with the sensitivity setting I found in the goggles(settings) to no avail. Where would the proper setting/control for this be found? Also, when using the goggles, do you/should you also still have your cell phone connected to the controller? Thanks in advance and I apologize in advance if this isn't the correct place to ask these questions...
OK, like all this stuff, you kinda need to just keep fussing with it. I finally found the gimball control in the goggles. I just did a short flight up about 100 ft and flew out a little bit from where I launched and about threw up! This is greatness beyond what I had imagined! |
