Ronin S full functionality with Canon 1DX Mii
3699 12 2018-8-31
ShamPh0t
I have news for you all. Follow focus, autofocus and record-start work with the 1DX Mii! I simply constructed a USB 3  to USB C female adapter and used the existing cable. It isn't pretty, but the functionality is there.
So DJI - when are we getting the proper cable?!?
2018-8-31
DJI-Paul
Flight distance : 41159547 ft
You can use the Micro USB cable now. It just plugs in to the bottom half of the port on the camera.
2018-8-31
sumoadam
DJI-Paul Posted at 2018-8-31 14:13
The supplied USB cable does work as mentioned, no need to build one.  All due to new firmware v1.4 introduced yesterday, just upgraded and follow focus working finally.
2018-8-31
ShamPh0t
sumoadam Posted at 2018-8-31 21:59
There is no supplied USB 3.0 cable for micro B, which the 1DX Mii has. That's why I had to stack adapters and use the USB C cable supplied.
Is it possible to order the cable at DJI? Anybody find a link?
BTW, I tested for the functionality BEFORE updating to 1.4. It was already accessible.
2018-9-1
ShamPh0t
2018-9-1
ShamPh0t
2018-9-1
ShamPh0t
2018-9-1
RBLAX
Flight distance : 1445702 ft
ShamPh0t Posted at 2018-9-1 02:25
If you take the USB-C and plug it into the bottom half of the USB slot on the 1DX2, it works. Just enable the  Camera Control in the app (select Canon).
I get focus wheel and record functions. Works like a charm!
2018-9-20
fans7c91fd5b
RBLAX Posted at 2018-9-20 11:26
This may seem like a silly question, but where in the app is camera control enabled. I've looked for this option and can't seem to locate it! As it is, when I connect my 1DX II to the Ronin-S using the DJI supplied micro USB cable, the red light on the gimbal focus wheel flashes, and the camera and gimbal don't seem to be talking to each other at all. Thanks!
2018-9-24
jamesflensted
Denmark
fans7c91fd5b Posted at 2018-9-24 12:00
I have the same issue. How do we fix this?
2019-12-6
CineView Media
Flight distance : 5365522 ft
Norway
I got the 1D X Mark III, when pluging in the USB-C cable to the RSS, i loose the live view, is it not supported?
2020-4-12
djiuser_pnZ2pOxX7Ywx
Slovenia
Hi, I also got Canon 1dx Mark III and I can not start shooting video from the gimbail control. I have connected USB-C cable to the RSS and actualli button on the stick does not work and even camera does not work if I try to start shooting with button on the camera. It is just a warning BUSY on the screen, so it obviously has some signal from the Ronin S bit I have no idea what to do. Firmware is the latest available.
Please help
2020-4-30
gt3rs
Flight distance : 280056 ft
Switzerland
Currently 1Dx iii is not supported. I did ask on another thread. Hope they will add support soon.
2020-5-1
