djiuser_vAht94ClG9Uw
Flight distance : 214354 ft
Hi everyone,
So I was flying under some trees in a wood the other day about head height, was just about to land then my return to home kicked in. I didnt cancel it quick enough and it went up into the trees above, bashed itself around for a bit then came crashing down.
It wasnt too hard of a landing. Two props were broken, but it must have landed on one of the front arms as there are two issues with it:
1) The fold out landing leg is loose and moves
2) The motor on the same arm now feels looser when i manually move the prop around (it doesnt have those clicks the others have and just turns)
I replaced the broken props and did a test flight with no problems. It feels exactly the same in the air as before.
I have Care Refresh so could use one of my two claims. Would you lot just keep flying and save the claim or should i send it in? Part of me thinks well if it flys ok then keep useing it. The other half is thinking it could fail midair when im over an area i cant retrieve it and then i wont be able to claim at all.
Thanks,
James.
