Drone Settings!
1114 20 2018-9-2
Mini-G
Flight distance : 663304 ft
Hi all,
I've been playing around with my Mavic Pro's picture settings and noticed what a huge different setting your sharpness to +1 vs -1 makes.
So after months of testing and countless YouTube videos, I'm finally using the Picture settings +1, -1, -1.
What do you think & what do people use?
Thanks & enjoy!!
2018-9-2
Montfrooij
Flight distance : 2560453 ft
Looks good!
2018-9-2
FntX
Flight distance : 158734 ft
Looks very nice!
Settings heavily depend on the type of scenery.
If the landscape is what should be sharp then it's definitely  +1/something/something because when using a setting below +1 the foliage is becoming muddy and the best to describe this effect is an oil painting effect.
When going up close and personal to a subject it's 0/*/*
For a good shot I've noticed that using the manual focus with focus peaking is the key. Also recording in 2.7k instead of 4k makes a huuuge difference in image quality. I've chosen to record higher than 1080p and scale it down to 1080p which increases the quality even further.
0/0/0
+1/0/0
-1/0/0
This becomes even more visible when birches are involved
The same settings (0/0/0) used produces very different settings and as you can see, the trees an bushes in the background are affected by the noise reduction of the camera whereas the car in the front, as well as the trees 5m away aren't.
2018-9-2
Mini-G
FntX Posted at 2018-9-2 22:55
Looks very nice!
Yes I agree!
Thanks for you feedback!I will also try out shooting at 2.7K, I’ve never tried that before.
Have you got a clips to share?
Has anyone found 2.7K better quality than 4K?
2018-9-4
A CW
Flight distance : 13838848 ft
Very good
2018-9-5
Gregbella
Looks good
2018-9-5
Gregbella
Where abouts in Australia do you live
2018-9-5
FntX
Mini-G Posted at 2018-9-4 22:53
Yes I agree!
Currently I have exact one clip to share
It's been shot using 0/0/0
2018-9-5
Mini-G
FntX Posted at 2018-9-5 04:05
https://youtu.be/8Pfrl6OHxF0
Hi FntX,
Yes I see it! Even the tree behind the car looks super sharp to me (it's the first thing that stood out).
Also the car is very crisp! Thanks for sharing!
2018-9-6
FlyDK
Flight distance : 1636286 ft
Denmark
Looks great - I'll try that too.
Thanks for sharing.
2018-9-6
Woe
Flight distance : 4129268 ft
Looks good, think I will give it a try
2018-9-6
FntX
You're welcome! If the foliage is too blurry then increase sharpness to 1. Not higher!
2018-9-6
Jos A
Flight distance : 73209 ft
These are my settings and example
Manual exposure, D-LOG, Style 0,-2,-2, sunny
4KUHD, NTSC ,30 FPS, ISO 100
2018-9-6
Jos A
and this one , same settings only style 0,-1,-1
2018-9-6
Jos A
Mini-G Posted at 2018-9-6 02:58
Hi FntX,
It's is sharp but the drone and or object isn't moving.
2018-9-6
Mini-G
Jos A Posted at 2018-9-6 10:21
https://youtu.be/d8lJ9_6HspQ
Both vids look great!!!
I've been worried about losing reception going over a stadium.
Did you have any issues like this?
Thanks!
2018-9-8
A CW
Thanks for sharing
2018-9-8
FntX
Keep in mind that setting up the focus correctly makes also a huge difference. I've found that the auto focus ever so often has issues especially when foliage is invokved.
2018-9-9
Mini-G
FntX Posted at 2018-9-9 00:00
Hi,
This might sound like a noob question but do you have your drone set to manual focus all the time?
Also is this the same as flying to your set point, then pressing centre focus button?
Thanks!
2018-9-9
FntX
Always fully manual with focus peeking enabled. Since the cam has no actual infinity focus this means you have to adjust the focus manually when you significantly change the distance from the subject.
Tap focus looks wonky when recording video but works on stills pretty good
2018-9-9
davidmartingraf
Flight distance : 106566408 ft
I shoot in Vivid Mode and use +3, -3, +3 for my settings because I like the sharpness and rich color contrast.
2018-9-9
