Montfrooij
Flight distance : 2560453 ft
First of all: you are right. A recent iPhone takes very good pictures compared to the Mavic Pro.
And the best (for most users): you don't have to do anything. Just press the shutter button.
The engineers at Apple did a great job removing all the settings and creating an 'automatic mode' that suits a lot of situations.
DJI engineers are great at making drones, but so far have some way to go on the camera part.
But maybe we are spoiled by Apple
Next, the camera system of the Mavic Pro is not as good as that of your (recent) iPhone. Especially since there is no way to get around the DJI Go4 app and DJI's way of dealing with the sensor output.
(with Apple app developers can tweak this a little bit)
So again, DJI is not as 'good' as Apple has become.
So what can you do to get the best out of the Mavic Pro camera?
General:
- Use good lighting conditions. (enough light, sun coming from behind)- If there is a lot of contrast in the picture, try the AEB function and merge the 5 exposures in post.
If you shoot auto:
- Set your EV compensation to -1, this prevents over exposed area's. Or shoot manual.
If you shoot manual:
- Shoot at low ISO values ONLY (there are exceptions, but in general that is the only way to get the most out of your MP)
- Watch your histogram if you shoot manual (make sure the picture is not too dark (on the left) or too bright (on the right)
- You can try and shoot RAW, although that does require more post processing and if you follow the 'general' rules does not give better pictures per sé.
I usually shoot on 'auto', unless there is a need for manual.
With the -1 EV compensation I usually get decent results.
Editing:
- I use Affinity Photo for editing. Almost as good as Photoshop, but by far not that expensive (around € 50,- one time)
