Testing Active Tracking 2.0 blow my mind - part 2
740 21 2018-9-2
Andrejs
Flight distance : 1730177 ft
Latvia
After I made walk test between tries I decided to make harder test for Mavic and it's blow my mind. I was riding electro scooter with my daughter in wood.
I started with easiest part and ended with hardest. So look till end.
All footage was made with 1 take with 1 battery
2018-9-2
DJI Stephen
Super Moderator
Hi there, thank you for sharing of your awesome video using the Active tracking. Cheers!
2018-9-2
Mullheliflier
Flight distance : 4370984 ft
The new active track looks amazing. Thanks for letting us see what it can do.
2018-9-2
Andrejs
Latvia
Thanks. Yes, at least we know how far we can push it.
Also active tracking works best when it follow you. It's looks sketchy when it fly backwards. Need to test it more
2018-9-2
B1houdini
Flight distance : 790909 ft
That has to one of the coolest features on the new M2P.
Did it actually pause at certain location and then on it's own shoot forward?
Thanks for sharing.
2018-9-2
Paul_IA
Flight distance : 4603307 ft
Very cool video. Looks like the Active Track in the MP2 is pretty awesome.
2018-9-2
Andrejs
Latvia
B1houdini Posted at 2018-9-2 13:43
Thanks for sharing.
Yes. In one part it stopped. I stopped too that I was thinking that it will not fly there and after that it passed so gently all tries
It looks like it was calculating best path to fly =)))
2018-9-2
Chasing Light & Shadows
Flight distance : 221476 ft
Dude, at some point you're gonna end up with a broken drone, the odds are against you! Great video and thanks for doing this but quite whilst you're still ahead!!
2018-9-3
Andrejs
Latvia
Chasing Light & Shadows Posted at 2018-9-3 02:38
So far I never broken drone because of my fault. I had some crashes, but because of hardware faults what was warranty cases.
I had Care Refresh with Mavic 1 and never used it. I got with Mavic 2 too, because I think it is worth it. You never know what can happen. All what fly fall into ground anyway =))
I agree that it was very dangerous and I don't think that I will do so dangerous test again. But at least I know that I can trust it in more or less in open environment and if there will be some obstacle it will stop or fly around it. This is what all about was my test.
Thank you ;)
2018-9-3
Wachtberger
Flight distance : 261509 ft
This is truly amazing, thank you very much for testing and making the video!
2018-9-3
Andrejs
Latvia
Wachtberger Posted at 2018-9-3 03:03
Thank you ;)
2018-9-3
M Stuart K
Flight distance : 1267717 ft
That is amazing1
2018-9-3
Exib
Flight distance : 153760 ft
Well done I really enjoyed that did teh drone pause at 1.26 did you have to manually make it fly fowards so it could lock on again?
2018-9-3
chiplifter
Flight distance : 745180 ft
Nice video, Active track has seriously improved.
2018-9-3
Thriller
Flight distance : 374337 ft
Thanks for doing this test ! Did you have to fly manually using the controller when MP2 stopped?
2018-9-3
Andrejs
Latvia
Thriller Posted at 2018-9-3 03:49
Thanks for doing this test ! Did you have to flusso manually using the controller when MP2 stopped?
No, I stopped to look what will happens and it started to fly again. I didn't controlled Mavic at all. Looks like it was thinking how to fly best path
2018-9-3
Thriller
Andrejs Posted at 2018-9-3 03:51
Thanks Andrejs for the answer and sorry for "flusso" I meant "fly" but sometime my Ipad writes what it wants
2018-9-3
Andrejs
Latvia
Thriller Posted at 2018-9-3 04:00
I understood it like fly too I was thinking maybe it is some kind of Spanish or Franch
2018-9-3
jacksonnai
Very nice thanks for sharing your experience again
2018-9-3
Visual Air
Flight distance : 63655 ft
You really put it through the paces thanks for sharing
2018-9-3
Andrejs
Latvia
Some guys was asking about Active tracking and how it performs flying backwards, because all test with following you. Here my thoughts about it:
The problem with flying backwards is that Mavic didn't know path where to fly. So it fly backwards in straight line. If it see obstacle it stops and starts rotating (staying in one place). After that it starts following you, because it know where to fly. So imagine there is straight road and after it turns right. Mavic don't know that it needs to turn right when it flying backward.
2018-9-3
No Man's Drone
Flight distance : 301545 ft
This test is better than iPhoneDo's lol. Was APAS enabled as well?
2018-9-3
