Unstable Mavic Pro
1247 10 2018-9-3
fansd14c0977
Latvia
About two months ago i bought Mavic Pro. Everything was fine, until about a week a go i started to notice the mavic are not staying in place like it was in the start. Its slightly moving side to side, up and down. I tried to calibrate IMU and Compass, also turn of Propeller Cage mode. it's either are doing the same. What is the problem? What should i do?
2018-9-3
DJI Wanda
Hi. We apologize for the inconvenience. Did you try to refresh the firmware? Is there any error message showing on your screen?
2018-9-3
fansd14c0977
Latvia
DJI Wanda Posted at 2018-9-3 04:13
Just updated Mavic to the latest firmware, also tried to put off SD card to see is it's card problem, but still it's doing the same thing,
2018-9-3
fansd14c0977
Latvia
Also in P Mode it's speed is more then 30km/h then it was. Now in P Mode it's speed is up to 44km/h
2018-9-3
Aardvark
Flight distance : 384432 ft
fansd14c0977 Posted at 2018-9-3 06:35
Is Obstacle Avoidance switched off, if so then it will travel faster in P Mode. From about 36 kph to 58 kph according to manual (Page 11).
And if VPS off it might move about a bit while hovering.
2018-9-3
fansd14c0977
Latvia
Aardvark Posted at 2018-9-3 09:57
It's seems to be better. Thanks!
2018-9-3
Flybee
Flight distance : 2203983 ft
Sweden
fansd14c0977 Posted at 2018-9-3 23:28
You can also check if the RC needs calibration.
Good luck
2018-9-4
Flybee
Sweden
Did you turn on VPS or what did you change?
2018-9-4
fansd14c0977
Latvia
Flybee Posted at 2018-9-4 11:27
I did all the things - Calibrated RC, VPS in Assistant 2 (there is a lot off videos in youtube how to), Compass, IMU. After that i turned on Obstacle avoidance, it seemed to be better, but theres still had slightly moving, i don't know what was the problem, but after that i tested it going upwards and somehow i hilted tree, now my Drone is broken and i am hopping for DJI service to help me with fixing my drone back leg.
In my country theres no places where i can fix my drone, LATVIA it is.
Sad story to me.
Fly with caution.
2018-9-4
Flybee
Sweden
fansd14c0977 Posted at 2018-9-4 23:32
I have to check if I have Obstacle avoidance on or not. Thanks for your input.
I'm sorry for your missfortunate.
The guys in Holland or Germany could most likely help you with the leg.
Hope you get it fixed soon
2018-9-5
A CW
Flight distance : 13838848 ft
Try calibrating the VPS using assistant 2
2018-9-5
