Mavic 2 pro firmware update failures
3500 16 2018-9-3
fansd7474eb3
I've had a Mavic Pro for years... so I know how to do the firmare updates, and I updated the old Mavic Pro last night without any issues using the same network/pc/phone I used below..
Bought a new Mavic 2 Pro today and just cant get the firmware update to complete...
The controller did update using DJI assistant after several persistent attemps but the bird just refuses.
Current M2P v00.06.0000, attempting to load V01.00.0000
My WiFi and Internet are working just fine.
I've tried:
1. using DJI Assistant v1.2.0 - the download runs for a variable amount of time then fails with "Update failed", "Network Error". I'm using the supplied cable both in USB v2 and USB v3 ports. Sometimes it even gets to 100% downloaded then fails.
2. Using the controller and a Samsung Galaxy S9+ with the side usb port and the big usb port in the middle - the update never starts and always reports "Network Error" I tried using both WiFi and 4G and get the same error.
3. I've tried every combination of usb/controller/one/both/fingers crossed etc but always the same error. restart between tries or not doesnt make any difference.
I've used up two batteries trying this this afternoon but no success,
Does anyone have any ideas of what else to try?
Can I download the file manually and put it on the SD card or something?
Thanks,
C
2018-9-3
msinger
Flight distance : 183694 ft
Try upgrading to DJI Assistant 2 version 2.0.0. You can download the installer here:
https://www.dji.com/mavic-2/info#downloads
2018-9-3
DJI Wanda
Hi. We apologize for the inconvenience. Did you try to install the DJI Assistant 2 For Mavic v2.0.0?
Here are the links if not:
For windows: https://dl.djicdn.com/downloads/ ... For+Mavic+2.0.0.zip
For Mac: https://dl.djicdn.com/downloads/ ... For+Mavic+2.0.0.pkg
2018-9-3
UCBarkeeper
Flight distance : 616982 ft
Switzerland
my friend couldn't update with his android phone (samsung galaxy s9), update worked with iOS.
2018-9-3
windsurfkruzer
Flight distance : 83927 ft
Exactly same here with samsung S9. I went the "assist 2" option on my pc, used the cable directly from usb port to bird and Presto, watched the lights flash for 10 minutes or more. Same process worked for the RC
2018-9-3
fansd7474eb3
Ah yes, thanks everyone.
DJI Assistant 2 for Mavic works fine.
Silly mistake. ALl upgraded now.
2018-9-3
DJI Wanda
fansd7474eb3 Posted at 2018-9-3 04:22
That's good to know. Please let us know if you still need more help.
2018-9-3
djiuser_ZpfnB8fGIJHl
I am having the same problem, but DJI Assistant 2 V2.0.0 also won't connect to my Mavic 2 Pro. I can see that it has connected to my PC and can access storage, but the Assistant program just continually displays the circular image showing the usb plug and arrows towards a computer port. It seems like the two aren't talking to each other. I have tried uninstalling and re-installing the assistant software, but no better.
2018-9-3
Mike-the-cat
Flight distance : 14411854 ft
Singapore
djiuser_ZpfnB8fGIJHl Posted at 2018-9-3 21:26
The remote must be off for Assistant 2 to work. Either that or update wirelessly via remote. If you have both connections, the update won't load.
2018-9-3
Gomez Garcia Gonzalez
Mike-the-cat Posted at 2018-9-3 22:03
Thanks, I tried this and again I can access the sd card and internal storage, so the drone and pc are connected, but the software doesn't reognise the connection and the drone LEDs just flash yellow.
2018-9-3
Same thing if I connect the controller to the pc, it pops up as connected but the assistant software does nothing.
2018-9-3
I have eventually done the firmware update successfully by using DJI Assistant 2 for Mavic, though it only worked on the second pc I tried and even then the drone update took three attempts (connection kept dropping out), though the RC worked first try. Not a relaxing experience!
2018-9-4
djiuser_HoGh73hJZcrN
Flight distance : 16804 ft
Non riesco ad aggiornare mavic 2 zoomm
2018-9-28
DJI Wanda Posted at 2018-9-3 06:28
Non riesco ad aggiornare mavic zoom
2018-9-28
Serratus
Norway
I managed to get it to work by alternating between the DJI GO 4 app and doing several reboots, then doing the DJI assistant 2, then the GO 4 app again.
2018-9-28
fans86384b4f
Indonesia
when you try to upgrade the firmware with your USB connection to PC using dji assistant 2
...dont forget to connet the remotte with the aircraft  as well.....
2018-10-18
djiuser_XwFxWH8PIgK5
Hoi ik heb pas de marvic pro 2 gekocht maar nu laad me telefoon op tijdens het vliegen. Heeft iemand hier een oplossing voor
2019-2-16
