Ulysses Paiva
Flight distance : 573310 ft
Hi, Susan!
Well, it is compatible in terms of being able to connect (via USB), but it's not a full compatibility. A lot of functions are not available using the goggles, like it doesnt show all the frame rate options (and some other settings on the software side that are already available inside Go4 app). You cant use both goggles and smartphone at the same time, you have to disconnect/unplug one to conect the other so you even dont have a button within the app to switch between them. When you disconnect the goggles, it always change the Go4 app wifi setting to 2.4Ghz (I mostly use 5.8ghz) even though its connected via USB cable. You have to first take off with the phone then unplug it, plug the goggle and only then you can use it. And some other functions not present inside the goggles which are present in the Go4 app (battery level bar with RTH estimation and others). It's not fully compatible, it only "works".
It also doesnt save flight logs as Go4 App does nor saves any feed cache as I can do with my phone. And it did cost me the price of a flagship phone that now I realize I should have bought with a cheap FPV solution like VR Box and I would have a much better and useful tool.
There is one simple solution that could make it all work at once: making it able to use both at the same time! As it is already happening with other models. The way it already is, simples as that. So I could change any settings inside the app regardless what goggles have or have not, check RTH battery estimation, I wouldnt have to plug/unplug several times for a single flight (which is cumbersome and more of a workaround than a real feature) and all the rest, and I would only need to flip the goggles up, take a look at what I want inside the app, then flip back to using the goggles within seconds and even without removing the gogglos from my head. And needless to say how much safer (big time!) it would be to fly that way. And its only 1 change away from it.
