TheMann58
Flight distance : 18669501 ft
Photos (frame grabs) taken while recording video should be in the same DCIM directory on the microUSB card that was in your Phantom 4/4 Pro camera as the video files and full-res photos taken in photo mode.
Note: To capture an HD-resolution frame-grab photo while recording up to 4K video, you can tap the solid white dot above the red video circle on the right-side of the DJI GO 4 app. While the photo is being captured, the white dot turns gray and a circular arrow appears around the circumference of the white dot for a couple seconds to let you know the image is being captured. You cannot capture another photo until the solid white dot reappears. Did you witness all that while you were capturing your 14 frame grab photos?
I captured over 100 stills in this manner while simultaneously recording 4K/60fps video of a 5K run this morning on my Phantom 4 Pro.
