DroneMapper
Flight distance : 6880 ft
Hello,
For what it is worth, we just setup a clients Inspire 2 with X5S using GS PRO without any issues. We updated everything (Controller, Camera, Image Processor, I2) to the latest firmware. The drone performed the mapping mission without problem. You might double check the camera orientation setting.. it can be parallel or perpendicular to the flight line. I can't remember if this is in the advanced settings or not. We also set the cross track and in track overlap to 80% under advanced settings. You should also use the setting which triggers the camera based on distance instead of time.
Hopefully that helps. Best of luck
Thanks,
JP
https://dronemapper.com |
