3-D
Flight distance : 635764 ft
Image quality was great, so it looks like you got the camera settings good. I agree with Bing, and everything that he said in terms of editing. Transitions from scene to scene need to be timed better.
When I first started editing (WAY back in May ) a fellow pilot @StanfordWebbie gave me this advice: "... challenge every scene in your video and ask yourself, "Would my video be worse if I removed this?" If the answer was "no", then cut that scene. " I've quoted him on that several times, because that simple statement has made me question every video I edit with a different eye. Learning how to speed up a shot to get the point of the scene across, while still keeping the viewer attention, or the proper time to use slow motion, are things that you will learn as you continue. Timing means a lot. The most important thing is to keep doing it. Keep flying, and keep making video. The more you do it, the better it will get!
Thanks for sharing your video!
