Rustic17
Flight distance : 2733760 ft
Edit: I am now going official with the organization being called U.S. Spark Forum Model Aircraft Organization and the eight safety guidelines listed below. To meet the FAA requirement of being part of a nationwide community-based organization (CBO) with safety guidelines, all you have to do is Reply to this post that you have joined the organization. See below for the earlier posts regarding the initial preparatory work in establishing this organization and guidelines. This post will be the only record of organization members. You do not have to give your full name. If you were ever questioned by an authority, you could sign into the forum using your username and password, show your reply stating you joined, and that should be enough evidence you are part of the organization.
To fly under the FAA Special Rules for Model Aircraft, you must ensure "the aircraft operates in accordance with a community-based set of safety guidelines and within the programming of a nationwide community-based organization (CBO)." Go to https://www.faa.gov/uas/getting_started/model_aircraft/ to see the criteria you must follow to comply with the special rule. All should read the two references in the second paragraph on the site...I plan to photo the documents and keep on my phone.
For all those who want to comply with the FAA and enjoy the status of "Model Aircraft", the FAA criteria for Model Aircraft status is pretty straight forward. Most forum members can easily meet all the criteria except for being a part of a "nationwide community-based organization" with a "set of safety guidelines." For this reason, I propose we establish a U.S. Spark Forum Model Aircraft Organization.
Organization safety guidelines dated September 4, 2018:
1) When flying under the Special Rule for Model Aircraft, the drone will be flown strictly for hobby or recreational use.
2) The drone is limited to not more than 55 pounds.
3) The drone operates in a manner that does not interfere with, and gives way to, any manned aircraft.
4) When flown within 5 miles of an airport, the operator of the drone provides the airport operator and the airport traffic control tower (when an air traffic facility is located at the airport) with prior notice of the operation. Drone operators flying from a permanent location within 5 miles of an airport should establish a mutually agreed upon operating procedure with the airport operator and the airport air traffic control tower (when an air traffic facility is located at the airport).
5) The drone will be flown VLOS (visual line of sight) of the person operating the drone. In other works, you (the operator) must keep the drone in sight at all times.
Note: These first 5 criteria are directly out of Public Law 112-95, Section 336 that the FAA documents reference.
Note: The following safety guidelines are added and can be modified or added to, as required...I need your input. The idea is that these are "guidelines", not regulations.
6) With public safety in mind, drone operations should be planned to minimize potential damage to property and persons.
7) Adhere to all airspace restrictions. Avoid affecting responders to emergency situations.
8) When possible, avoid flying near other aircraft.
Note: I have specifically left out safety guidelines referencing max altitude as this is not addressed in the Special Rule for Model Aircraft. Criteria 5 and 6 would pertain to this area.
Please send corrections or additions you have for the above criteria. The idea is we first finalize the organization's safety guidelines. Once we have the guidelines, all one has to do to join the organization is Reply to this post saying they acknowledge the safety guidelines (by date of revision) and have joined the organization. New guidelines and changes to existing ones can be made at later dates. Once you join, you've met the "nationwide community-based organization with safety guidelines" criteria for getting "Model Aircraft" status.
This post was revised/edited 09/04/2018...added clarification to Guideline 5 and 7. |
