Mavic Pro 2 Atti Mode?
12Next >
18623 41 2018-9-3
LeafPeeper
Flight distance : 450075 ft
One of the big complaints with the Mavic Pro was that we couldn't manually select ATTI mode.  Did they fix that with the 2?
LP
2018-9-3
Fraggboy
Flight distance : 81401 ft
They did not provide us the option to switch into ATTI mode.
2018-9-3
LeafPeeper
Thanks.  Just more reason to wait for the P4P2 successor...provided they don't take it away from the Phantom series.
LP
2018-9-3
gnirtS
Flight distance : 5712575 ft
The  old versions of DJI assistant still work to remap the switch on the M2 apparently.
2018-9-3
Fraggboy
gnirtS Posted at 2018-9-3 16:47
Thanks for sharing that.
2018-9-3
DJI Natalia
Hi there, Thanks for bringing this query to us. Mavic 2 Pro ATTI mode is also the same. It will automatically change to ATTI mode when  GPS signal is weak.
2018-9-7
LeafPeeper
DJI Natalia Posted at 2018-9-7 12:12
Yeah...I was hoping for the option to force ATTI mode like with the Phantom series.  I hope whatever replaces the P4 has this option.   If you want to be a good pilot, you need to be able to fly without GPS...
LP
2018-9-10
hallmark007
Flight distance : 9827923 ft
LeafPeeper Posted at 2018-9-10 10:56
LP
I wouldn’t think that’s necessarily true, there are hundreds of good pilots flying mavic’s , for $50 you can buy a cheap drone to practice Atti mode, or would you prefer to risk your $1500 drone. Remember when flying Atti mode or practicing Atti mode you always have the option to switch back in an instant to gps. With a training drone you don’t get that option, so really you might be better off practicing for what might happen without failsafe.
2018-9-10
JohnnieYaz
Flight distance : 5137874 ft
Atti mode saves power and can train pilots for the what if scenario. Flying indoors I personally want it off and not going in and out. I instruct new pilots and what better then to do it on your actual unit.. Would love the option to disable gps.
2018-9-10
GhostWolf010
Flight distance : 1118323 ft
Austria
I would love to manually select atti mode for flying indoor. I had 2 times now that it suddenly got a GPS signal trough the windows, and suddenly the drone flew into the window or a wall, because the GPS position was incorrect, so I don't fly indoor anymore
2018-9-10
Exib
Flight distance : 153760 ft
Can we have firmware so we can select Atti mode?
2018-9-10
GhostWolf010
Austria
Or just put it as an intelligent flight mode? That should not be to hard to do
2018-9-10
djiuser_ORT03tqNgLhm
Flight distance : 2217402 ft
GhostWolf010 Posted at 2018-9-10 13:49
I've been saying this since I got my Mavic one cinematic mode is a bit like attitude mode but I think it still uses GPS.
DJI please give us atti mode in intelligence mode please for the Mavic 1 and 2 drones. When you are flying indoors.
2018-9-10
UCBarkeeper
Flight distance : 616982 ft
Switzerland
cinematic mode is a bit like atti mode? are you stoned?
2018-9-10
LeafPeeper
RE: Mavic Pro 2 Atti Mode?
JohnnieYaz Posted at 2018-9-10 13:34
This...exactly.
2018-9-11
El_pierre
Flight distance : 1568 ft
Belgium
I'd personally love this feature. I'm in the middle of getting my licence and need to practice atti a lot in preparation for the exam. As stated above, getting to know how to fly your drone manually is important for bringing it down safely in case of technical problems.
2018-9-11
LeafPeeper
El_pierre Posted at 2018-9-11 22:20
Where do you need to learn to actually fly a drone in order to get your 'license'?    Not being sarcastic here - I got my Part 107 in the US and frankly it's interesting that you could get it without ever having flown a UAS.
LP
2018-9-12
CoreyB10
Flight distance : 1665023 ft
Bit like learning FPV. Go direct to Acro mode and don't use Angle or Horizon modes. Only switch to angle for landings as is common with a lot of FPV loons. Love it.
2018-9-12
El_pierre
Belgium
LeafPeeper Posted at 2018-9-12 09:40
LP
I live in Belgium unfortunately. Drone law here is just ridiculous. Not higher than 33ft without a licence, aircraft less than 1 kg and only in yer backyard. You have to study for theoretical tests (which are actually light manned aircraft tests) and do some practical tests with and without GPS turned on. Total cost of all this +- $4K. Yeah... Upside is drone accidents are uncommon here
2018-9-12
LeafPeeper
El_pierre Posted at 2018-9-12 11:12
Wow!  Kudos to you then for not only putting up with it, but for continuing to persevere!  Congrats!
LP
2018-9-12
pjollain
Flight distance : 106093 ft
If you live close to the border, cross it and come to fly in France! There are some restrictions, but we can still easily find places where to fly. A light theoretical exam is coming, but it will be free.
2018-9-12
El_pierre
Belgium
pjollain Posted at 2018-9-12 21:07
Thanks for the tip, I actually thought about doing exactly that. Going to France or The Netherlands where drone rules are as they should be. I live about an hour and a half away from the border to France.
2018-9-12
cicciopilota
Flight distance : 36624 ft
Personally I am participating to a training to obtain license to work with drone , and indoor with metal etc if droni switch automatic from gps to atti is very dangerous, with a ph4 you switch and is made, possible not to do with mavic, with software someone change parameter in system worth dji assist, so if can do a user come on dji make more re.alistic and made you, you will sell more mavic than expected hope will see soon on mavic capability to choose like flight
2018-10-15
Lolo780
Flight distance : 35122792 ft
Luckily the M2 has a 3 position flight mode switch so you don't have to give up Sport mode like the Mavic 1.  Use DJI Assistant in debug to replace Tripod mode (12) with ATTI mode (3).
2018-10-15
jffry7
Flight distance : 27566 ft
Singapore
Lolo780 Posted at 2018-10-15 17:12
Never thought of the debug mode, I might try this later
2018-10-15
Tom_A
Flight distance : 899951 ft
hallmark007 Posted at 2018-9-10 11:20
Only half agree with this. While it’s best to practice first with an inexpensive drone, it would be nice to be able to test how the Mavic is going to behave in atti mode after practicing with the cheap drone.
2018-10-15
Prometeo
Flight distance : 94304 ft
Costa Rica
Did anyone try the MOD?
I need it to fly over equipment in big factories.  But the ceiling has strips of transparent polycarbonate that allows GPS to pass and... well.
You can't please everybody but, Lens and F distortion, precision landing, ATTI mode, FCC&EC, micro USB side.
Dear DJI, this is an awesome machine! please be a little more preemptive on you loyal clients needs.
2018-10-21
Prometeo
Costa Rica
I will try some controlled flights.
https://expertworldtravel.com/dji-mavic-pro-what-is-opti-mode/
2018-10-21
cicciopilota
Is incredibile that mavic not have atti why not like ph4 or autel evo is a firmware update easy
2018-10-21
fans89eaf4d1
Flight distance : 39603 ft
Did anybody tried now this atti „hack“ with the Mavic pro2?
I don’t need the sports mode - so which numbers to change?
Thanks!
2019-1-17
Brett Brandon
The new CAPTCHA crap is the last straw.
Im tired of DJIs crap and am removing my posts and will be on my way.
2019-1-17
djiuser_WnaEdXQ62sqV
Flight distance : 1047 ft
Sweden
Is there any word on warranty if changing one of the switch positions to ATTI using DJI assistant?
I'm about to get a drone and want the Mavic over the phantom for the portability but not being able to fly in ATTI on demand is kind of a deal breaker. I don't understand why a drone with pro in the name does not allow for this. I can't fly indoors without forcing ATTI without risking a spotty GPS signal sending it into something.
2019-2-13
fansc2e33663
Flight distance : 2549216 ft
Switzerland
How do I switch to Atti mode manually?  It’s a bit pointless if you can’t practice flying in Atti mode, right?
2019-3-15
hallmark007
fansc2e33663 Posted at 3-15 04:55
Why is it pointless , you can buy a cheap drone to practice with , chances are when practicing you will crash it. But at least it won’t be the drone you paid €1500 for, if you think that nobody crashes when practicing Atti mode you’d be wrong, yes you can switch back to gps if you have a phantom , but you can’t switch any drone back to gps when it’s not there, so a much truer version of practicing Atti mode is with a cheap drone that doesn’t have gps and if you can master this you won’t have any problems with your M2.
2019-3-15
Brett Brandon
2019-3-15
Robert R
I fly off moving boats and ATTI mode is a MUST!  I put my Phantom on the deck of the boat and I'm able to match precise attack angle and lift off smoothly and safely.  Without ATTI mode I'm absolutely unable to fly my Mavic safely as it's attempting to return to it's initial startup location as soon as you power up.  I've also flown from the tops of mountains which create interference with the GPS and not just block it but make it believe it's flying at speeds or changing directions.  It NEEDS to be user selectable for some flight situations.  And I've seen how all of you talk about why risk flight on a moving boat or over cliffs and mountains... Because, I want THAT shot, that's why.. And it's MY drone, so I should be able to select the flight mode manually if I choose.
2020-1-7
High Altitude
Flight distance : 2106545 ft
Lot of people asking about this walk around in DJI Assistant and here’s all I can find, and at your own risk..  https://www.thedroneu.com/blog/atti-mode-mavic-2-pro-hack-zoom/
2020-1-16
Beeworld
Flight distance : 190259 ft
UCBarkeeper Posted at 2018-9-10 14:42
Hilarious!
2020-1-17
Beeworld
That's hardcore! Way more relaxed here in Australia (and probably way more drone crashes too!) - be interesting to see if there's any data to show whether this hardcore regulatory approach actually makes a difference.
2020-1-17
Avronaut
Flight distance : 53996 ft
As an experienced helicopter pilot, I would welcome an ATTI mode. That would greatly simplify cinematic recordings
2020-1-25
12Next >
