Ches_X
Flight distance : 509987 ft
Czechia
Hello,
I use FC Omnibus F3 OSD with latest Betaflight 3.5 and latest aviable FW (up to now aviable via DJI Assistant) for Googles RE and Ocusync Air unit. I have enabled telemetry output in betaflight via MSP with 115,200 bit/s. I have problem with freezing telemetry data in Googles. After powering up air unit (googles already running and in race digital mode), telemetry in googles is sometimes shown (sometimes not, succesful in aprox 80% of boot-up) affter sucessful connection. If telemetry shows up, than immidietly freezes and stays static until reboot of air unit. If I reboot Googles, then after sucessful connection show N/A values. Image form camera is working always witout any problem. I see others with similar problem when telemetry is working well until arming copter, but in my case, telemetry freezes immidiatly after powering up (show correctly only first reading of voltage, current, altitude and artifical horizont (I don't have GPS module, so GPS is always N/A)) and arming/disarming does not change this state.
I try some advise like setting speed to 57600 bit/s or set protocol to MAVlink or SBus (with different baudrate), but telemetry not working at all or as described above. If I hooked up
osciloscope on UART Rx and Tx, then communication betwen FC and Air unit seems correct (with baud rate 115200 request and response) and work from powering up unit to disconnect battery.
If I use another solution of telemtry transmission and connect telemetry to same UART on FC to Frsky X4R-SB reciever, then with Taranis QX7 RC the telemetry is working witout any problem.
Any suggestion how to make telemetry data work correctly (flying without at least actual battery voltage is pain in the a*s)?
Thank you for reply.
