A2 Assistant Software v1.8 is now available
5735 12 2015-5-29
mrwolf
Flight distance : 65404 ft
As per topic.
A2 Assistant Software v1.8 is now available from.....
http://www.dji.com/product/a2/download
2015-5-29
asif_bhimji
Flight distance : 323540 ft
any special instructions install/firmware update? I saw there were some for v1.6.
2015-5-29
knarfboy
Flight distance : 494508 ft
asif_bhimji@yah Posted at 2015-5-29 21:01
Mystery, why the Assistant 1.8 say's "Firmware missmatch" and update the FC Firmware from 2.5 to 2.5 ???
After update the error message is gone. Does DJI has a new 2.5 FC Firmware?
2015-5-29
coinfaslab
Flight distance : 153343 ft
knarfboy Posted at 2015-5-30 02:30
Mystery, why the Assistant 1.8 say's "Firmware missmatch" and update the FC Firmware from 2.5 to 2 ...
It can be ... mystery
2015-5-29
knarfboy
I think, DJI fix one or more bug's in the v2.5 firmware without change the version number.
2015-5-29
mrwolf
  Thanks to Tahoe Ed DJI Support.
A cut and paste for you guys here.
There was issue with the v1.6 Assistant and v2.5 firmware. A few users experienced the motors going into uncommanded motor test. DJI removed the Assistant out of an abundance of caution. v1.8 will be introduced shortly.
2015-5-29
coinfaslab
I upgraded the firmware, with the assistant version 1.8
IMU and compass recalibrated
remapped radio channels (graupner mx-20)
no particular problem
Tomorrow testing in airfield
2015-5-30
johannes
Flight distance : 771434 ft
Iceland
Those of you getting Assistant 1.8 Firmware missmatch message after upgrade could be caused by launching the older assistant by using the shortcut for the old Assistant. Be sure you are using the Assistant 1.8  shortcut not the one with  Assistant 1.6 in the shortcut´s name.
Happened to me! It´s like the installer does not remove the older version.
2015-6-1
dennismurry08
Flight distance : 5948264 ft
johannes@digi-f Posted at 2015-6-1 21:34
Those of you getting Assistant 1.8 Firmware missmatch message after upgrade could be caused by launc ...
can someone tell me the need to do the upgrade? My 1.4 is running just fine...???
2015-6-1
coinfaslab
dennismurry08@c Posted at 2015-6-1 23:38
Relase
2015-6-2
ahmed214
after updating the firmware to 1.8 , i m getting intermittent beeps from my ESC.....and secondly the controller constanntly blinks red, giving me the transmitter mid point error..i hav calibrated the transmitter multiple times...also the slider of all the sticks is at the middle position in the assisatnt software...any ideas?
2015-6-2
johannes
Iceland
Did you re check all settings? You need to go through setup  after firmware update, check channel mapping and all inputs from your transmitter.
2015-6-3
cruddbucket
Flight distance : 764 ft
Hi guys, just updated A2 MC to 2.5 via 1.8 Assistant software.
Now mode selection switch has to pass through MANUAL mode when I change between ATTI and GPS mode.
My question is:
When changing from ATTI to GPS and GPS to ATTI respectively, does the aircraft go in to manual mode for the brief moment when the switch is in the middle position?
I expect the aircraft will increase in throttle momentarily... can anyone please confirm wether this is the case?
Regards
Luke
2015-6-26
