Mabou2
Flight distance : 811257 ft
Hi all,
UPDATE: I got the firmware update to work, see next post below for explanation... might help you if you are having the same failed update. Bottom line; the update failed 100% of the time until I unplugged the Ronin to GH5s USB control cable. Even though the camera and gimbal were both turned off during the firmware update attempts, as soon as I unplugged the USB side of the cable from the camera, the update completed successfully.
I'll leave the posts below as-is so you can see if this problem is similar to a problem you are having.
I had posted this same info to the Announcement post for Ronin-S Firmware: v 1.4.0.30 on 8-30-18 Strangely, this post is only on the Ronin home page, not the Ronin-S page.
Anyway, I tried updating today and it is a bit of a mess.
Basically, DJI Assistant 2 fails at 81%. I followed the steps to try again (including booting and shutting down the Ronin, quitting the apps, rebooting the computer, etc) and noticed that DJI ASS2 says the firmware is updated and only gives me the opportunity to "Refresh". I tried to Refresh several times and the update only got as far as 61% before it says it failed again. Now it only makes it to 61% each time.
The enclosed image shows the errors I got on the first attempt to update. (note that when the error page comes up, it says Update completed at 100%).
The latest version of the Ronin app on the iPhone now says that the Ronin-s Firmware version is "N/A".
Overall, not a great experience, but this is what we have gotten used to with DJI firmware updates. FWIW: the only thing I can test to see if the gimbal is updated is the shutter release button half -press and quick full press, and they seem to be working with the new functionality. But I feel like my firmware update is not solid and things might show up down the line. "NA" firmware version is not satisfying.
