jfftorsrud
Flight distance : 9475 ft
I upgraded to the 3.2 Assistant, 3.4 was not out yet.
In my upgrade section it gave me the new 3.08 firmware upgrade, which installed fine.
It also indicated there was a Battery Firmware Upgrade, which I proceeded to do. About half way through the upgrade, the software gave me an error message and stopped. When I shut down the Assistant Software and Removed the battery, the Battery would not even show any Green Lights and was apparently DEAD! Placing it back in the Phantom, the battery was still DEAD and would not work.
Figuring I might have damaged something in the Phantom itself, I removed the DEAD Battery and replaced with a NOT YET Upgraded Battery. Fortunately, the Battery worked fine and the Phantom worked fine.
So, it was a problem in the 3.2 Assistant that caused the Battery to be DESTROYED or At Least the Battery Firmware.
That's about it.
