Mavic 2 and white goggles bug in German translation!!!
601 4 2018-9-6
djiuser_2HKPfCFnaUaz
Flight distance : 58819 ft
When trying to pair the goggles with the Mavic 2 the German language ony shows Mavic I, in the English system it says Mavic II  in the same place, so in order to link you have to select Mavic I !!!!!
Or switch to English altogether.
PS this has caused me two nights updating and refreshing software and firmware and various posts (which eventually helped locating the root cause).
2018-9-6
DJI Natalia
Hi, we're sorry for the inconvenience caused. Can you please change the language of your Goggles by turning on your DJI Goggles > look for the toolbox icon on the right side corner > click settings > once there you will see a lot of option and please go down until you see language and click that > from there you may now change your language to English. For reference, please see the attached image below. Thank you.
2018-9-6
I know this is how I found the problem
2018-9-6
DJI Natalia
djiuser_2HKPfCFnaUaz Posted at 2018-9-6 13:35
Can you please try to refresh the firmware of your DJI Goggles via DJI Assistant 2? Thanks.
2018-9-6
i have done it three times, the result has always been the same, the German version is wrong !
2018-9-6
