Weapon Analyst
Flight distance : 530614 ft
Got the goggles today. Used twice. Both times I have had signal drop out far sooner than the remote usually does. When this happens of course the video drops out. If I do not act soon, the automatic return home will function. That would not be good in some conditions. I was under the impression from other posts on the forum that the goggles are essentially linked to the controller, (although we "link" the goggles to the drone) thus providing the same range. This must obviously not be the case. When the connection drops out, I have turned the goggles off and signal resumes properly to the remote and phone. There is no signal reduction shown in the UI icon that says, "You are getting close to getting a low signal be careful." it just gets choppy then the screen goes greyscale. What is happening here? The manual does not indicate a need for the pagota attachment since this is a dedicated DJI connection. Is this a bug or really the by design limitations?
Thanks folks.
The Weapon Analyst
