iphone 7+ vs 8+
1381 13 2018-9-7
Mer.ch
Flight distance : 39902 ft
Switzerland
Hello,
Seeking help/advice, I have read and read and read about devices that are compatable with the Mavic pro/DJI go 4 app and have concluded that an iphone is the way to go.
Now with that said, I am stuck with trying to decide beteen the iphone 7plus or 8plus. Reading through threads, many people state that the iphone 7plus works next to perfect, however, those post are from 2017 and earlier in this year many posts that the the dji go 4 app was constantly disconnecting.
Any recent input on which of the 2 divice is a better option?
with the go 4 app constantly being improved, is the iphone 7plus becoming (for lack of a better word) outdated? or is it still the better choice considering it is stated many places that the Mavic was designed around the iphone 7?
I currently use android that constantly dissconnects and crashes, I also dont know anything about iphones as I have never been a fan, so hoping to get some good advice and input to help me make the best choice.
Mer
2018-9-7
sittingduck
Flight distance : 29662 ft
No issues using 8+. I don’t have experience with any other devices.
2018-9-7
Mer.ch
Switzerland
sittingduck Posted at 2018-9-7 14:13
Thank you for the feedback!
2018-9-7
Oracle Miata
Flight distance : 3759829 ft
Just upgraded from a 6 to an 8+.  Go 4 has been taxing my 6 and my IPad mini4 since I started flying my M2P.  So far so good.
2018-9-7
Suren
Flight distance : 13425892 ft
South Africa
I use iphone 6s+ and 8+ with no issues
2018-9-7
Mer.ch
Switzerland
Thank you guys. So agin seems either one of the 2 I get should work. I used many android and they all have problems. I'll try to get the iPhone 8 plus if i can, if not then I'll settle for the 7plus.
2018-9-7
davidmartingraf
Flight distance : 106566408 ft
The iPhone 8+ has Apple's fastest A11 Bionic Chip.
2018-9-8
Mer.ch
Switzerland
davidmartingraf Posted at 2018-9-8 00:01
Thank you. I guess this would allow for smoother video transmissions at higher resolutions?
2018-9-8
DJI Paladin
Flight distance : 318 ft
They are both powerful devices and I'm sure it will work fine with the APP. Please let me know if you have other concern, we're here to help. Thanks for your support.
2018-9-8
A CW
Flight distance : 13864580 ft
Both work fine - the 8/+ has an A11 bio chip whilst the 7/+ has the A10 fusion - the GO 4 app is now optimised for the 8/+ so should perform a little effectively but the 7/+ works just fine.
2018-9-8
davidmartingraf
Mer.ch Posted at 2018-9-8 00:19
Yes it's Apple's fastest chip for a smartphone.
2018-9-8
Mer.ch
Switzerland
Thank you all for the input, I went ahead and pushed the budget a bit and got the iphone 8+. I must say I have taken it out a few times to try and it works great, no trouble so far while in flight. Only thing is I need to connect the phone via the usb port on the bottom of the controller. overall the app works smooth on the 8+, no crashing.
2018-9-18
G_Sig
Flight distance : 9109311 ft
Iceland
Mer.ch Posted at 2018-9-18 21:31
Can you confirm that you can set home point to Remote Controller?
2018-9-18
Mer.ch
Switzerland
G_Sig Posted at 2018-9-18 23:59
Hey,
Yes, as long as the phone is not in airplane mode I can manually set the controller as the home point in the settings.
I have seen many recommendations to switch airplane mode on when flying to have less interference with the antenna, however, when I do this I cannot manually set the home point in the settings. When airplane mode is on and the aircraft takes off it does give me the notification that the home point has been updated.
2018-9-19
