CantRepeat
Wachtberger Posted at 2018-9-11 10:42
Now the question is, does the recorded video correspond to what you had on the screen in the transmitted video or not? In my opinion the screen recorder does nothing else than recording what is displayed on the screen of your CrystalSky. It even does not matter if this is DJI GO 4 on the screen or any other app you are running there. Technically it therefore also cannot matter which aircraft you are flying.
From your screenshot I only can conclude that there is a video signal problem between your aircraft and the RC.
Well, the only time the video is washed out or lagged is when you try to screen record it. Recording what the bird sees using the dji go app record does not cause this issue.
It's only when you try to record the screen display. It has nothing to do with what the bird is sending. IE I can start recording the screen and also start the dji go record of the birds camera and while the screen record is completely washed out the bird video is completely fine. If the issue was with the transmission of video to the controller and then to the CS then the screen record of the CS view would also be washed out and lagged, but it's not.
It doesn't matter if the bird is recording or not. I can do just the CS screen record and it's bad. I can do both bird and screen and the bird's video is fine and the CS is bad.
I don't for sure know what the issue is but in the end you can't record the CS screen with issue. I've tried 5 or 6 different screen record apps. I've also tried the native android screen record binary and nothing works.
I don't know if it's bird firmware, controller firmware, or CS firmware or DJI GO app but there's many different combinations out there and more then one configuration of those apps have the same issue.
The other part of this is, I can screen record with an iPhone or other android device just fine. It only happens with the CS.
