Ready to fly Thermal solution using FLIR Bosun mounted on a MavicPro, notable this kit have been wired into the body and use the original power-source rather than a outside extra battery. very slick and easy to use.
I saw those Mavics at Interdrone last week. They are only available from Drone Nerds (since they modify them) and a warranty will only be offered by Drone Nerds after the modification is done. It's probably the best option available right now if you're in need of a thermal camera on a compact drone.
While I see this as a good option for a "budget" entry into thermal, the first videos that I saw with the first version were awful. Almost to the point where they were downright unusable. It's very reminiscent of how the old F450's that didn't have a gimbal to stabilize the footage. I see it more as a novelty than a true tool.
Exib Posted at 2018-9-10 11:57
Those lights are expensive $179 for the Mavic they look good though
https://shop.lumecube.com/collections/drone-products/products/mavic-pro-kit
What's $179 more after paying $4K to $6K for a Mavic fitted with a thermal camera?
