Lost Settings
1034 7 2018-9-10
AVT
Hi,
is it normal, that the Inspire 2 did lost the Settings for the camera?
Amost always after restarting the Inspire 2, I have to steup the Camera
Settings like: NTSC to PAL, automatik to manual, file-index from reset to
continuous, JPG to RAW, and so on.
Every cheap camera, also my last P4 and my actual Mavic 2 pro able to
keep the one time make settings for the camera.
Why is this simple function in the expensive Inspire 2 not possibel?
DJI: whats going on?
2018-9-10
DJI Wanda
Hi. We apologize for the inconvenience. Did you use a different mobile device? May I know what model of the mobile device are you using?
2018-9-11
AVT
Hi Wanda,
I use a cendence controller and a CrystalSky 7,85" Display.
All with actual firmeware.
Best regards
Uwe
2018-9-11
JBHDJI
Flight distance : 1043281 ft
Same here! I2/Cendence Master/StockRemote Slave..
2018-9-15
Rodger8
Flight distance : 20145135 ft
Are you checking the settings with the Inspire 2 powered up and connected to the Cendence?
2018-9-16
AVT
Rodger8 Posted at 2018-9-16 01:16
Hi,
I'm not sure what you mean?
At first I start the cendence, this will start the CrystalSky and then I start the Inspire 2.
2018-9-16
Rodger8
AVT Posted at 2018-9-16 03:22
Hi,
Everything has to be on and connected for your settings.
2018-9-16
AVT
Hi DJI,
actual firmware and the issue still on. Yesterday I had a commercial production with more than 20 fly, and I have to setup the camera settings for 5 Times!
Is there a chance, that DJI fix the problem at next time?
Best regards
Uwe
2019-7-22
