horizon correction via scrool wheel and C2 button
739 6 2018-9-11
fans589cba4b
Flight distance : 12780633 ft
is there a way to shortcut the m2 horizon correct like with the phantoms you do c2 and scrool the right wheel to instantly correct rather than going to the menu and correcting every time. lateral drift is getting annoying.
2018-9-11
FlyLowandSlow
Flight distance : 3505518 ft
this would be a nice addition
2018-9-12
curryisthebest
does the mavic really fly for 27 min?
2018-9-12
gnirtS
Flight distance : 5712575 ft
They only ever bothered coding that for IOS.  Android and Crystal Sky never had that option.
2018-9-12
DJI Tony
Hi. Thanks for the inquiry. I will confirm this information with our R&D engineers to clarify. Thank you for the support.
2018-9-14
DJI Tony
Hi, Thanks for the inquiry. Unfortunately, our Mavic 2 Pro does not have this capability. I would recommend calibrating the gimbal of your drone prior to your flight to see if the issue will persist. We will forward your concern to our R&D engineers to see what we can do. Thank you for the support.
2018-9-14
fans589cba4b
I know, so make it.
should be a simple bit of coding and a firmware update.
also still no trace active tracking functions.
2018-9-14
