I'm sure iPad air with 64 gb will be perfect for your Mavic Pro as long as the iOS version is 9.0 or later. In case you have an issue fitting your iPad to the RC, you can use this: (https://store.dji.com/product/pg ... esult-v2&position=0).
I am using the iPad mini 4 ,128 GB ,wi-fi only and it was the perfect one to fit the controller. Screen is large enough and bright enough that I hardly use a sun hood.
B1houdini Posted at 2018-9-12 06:50
same here using the same as my friend B1houdini with the same results.
