How often should we change the Propellers?
2173 10 2018-9-12
SBasso
Malta
Hey!
I do own an MA for the past 6/7 months, I never had a crash!
Is there any reason we should change them often?
Do they have life time use?
As nothing ever happened, they are intact.
However, I'm concerning regarding the quality of flights (not being paranoid) just seeking for safety!
Before opening this thread I tried to finds anything related and sadly, nothing is out there.
Thanks for your time.
2018-9-12
msinger
Flight distance : 228255 ft
You can continue to use the props until they become damaged. Check them carefully for damage (especially around the hub area) prior to each flight. Replace any props that strike a solid object (like the ground).
2018-9-12
Ex Machina
Flight distance : 1806362 ft
Forum search functionality leaves a lot to be desired, but this thread discusses DJI's rec to replace every three months -- Poll: How often should I replace Mavic Air's propellers?
2018-9-12
DJI Stephen
Hi there. thank you for reaching out. Regarding your question, It's not necessarily to change the propellers often, the only thing you will change the propellers when it's damage or not in a good shape.
2018-9-12
SBasso
Malta
DJI Stephen Posted at 2018-9-12 06:58
Sweet!
Thanks for answering that fast!
If you wish, we can remove the Thread!
Cheers
2018-9-12
SBasso
Malta
Ex Machina Posted at 2018-9-12 06:20
I'm so sorry!
I checked for and nothing came up!
My bad!
2018-9-12
PS013
Flight distance : 3579409 ft
SBasso Posted at 2018-9-12 07:12
I'm so sorry!
An easy way to search the forum is to use the SITE keyword in Google
For example, try the following in Google "site:forum.dji.com how often replace propellers"
2018-9-12
Ex Machina
I'm so sorry!
No worries! PS013's advice is what I rely on when I need to search -- in this case I had participated in the thread so just looked at my forum history. ;)
2018-9-12
msinger
Changing the props after X number of months really doesn't make much sense since props could become damaged even after only one use. Carefully inspecting them prior to each flight is really the best thing that can be done to ensure they are still in working order.
2018-9-12
Ex Machina
msinger Posted at 2018-9-12 08:56
The recommendation is to change them immediately if any damage is detected, otherwise, every three months, assuming typical use. Presumably this covers the risk of micro-stresses that may not be easily detected, and, in any event, replacing $10 props instead of a $1000 drone makes practical sense to me.
2018-9-12
msinger
Ex Machina Posted at 2018-9-12 09:15
Unfortunately, changing the props every 3 months will not offer you 100% protection from micro-stresses (if that's even a documented problem). You'll be much better off if you learn how to inspect the props and make sure you actually do it prior to each flight.
As I noted above, props can fail even after less than one month of use. So, don't get fooled into thinking that extra $10 you're shelling out is going to save your $1,000 drone.
2018-9-12
