Need Help Please!, Massive lag time between Controler and PP4
817 4 2018-9-12
fans500a68d3
Flight distance : 454616 ft
Panama
Good Evening All,
[size=14.666666984558105px]Over the last week, I have been experiencing major lag time between the sticks on the controller and the bird?. I have updated the latest firmware- the PP4, Controler and RE Goggles. I Calibrated both - IMU and Compass.
[size=14.666666984558105px]I am flying in the same locations at the same altitudes nothing has changed. On the last 3 flights I have had to use the RTH - WHICH WORKED PERFECTLY.
[size=14.666666984558105px]In closing, I have 100's of hours flying and take this hobby seriously. All suggestions welcome.
[size=14.666666984558105px]Kind regards
2018-9-12
Geebax
The time lag is caused by the delay in processing the return video feed at the display device. It is an MPEG4 transmission stream, and decoding delay is a fact of life in MPEG streams. The only thing that will reduce the delay is a more powerful video decoding function in the display, or anything that reduces the workload of the display device itself.
2018-9-12
James in Panama
Panama
Hi thanks for the feedback. However when I us the sticks.
I.E. move stick left the Bird delays the move doesn’t move for about a second and sometimes oversteers ?
2018-9-12
Geebax
James in Panama Posted at 2018-9-12 18:38
Try flying the aircraft right in front of you and watch it without the goggles or display. Does it delay then?
2018-9-12
Jenee 2
Flight distance : 7852129 ft
I assume this is happening without the goggles. Have you changed the setting to Follow rather than FPV without the goggles? Have you changed any of the other sensitivity settings such as yaw?
2018-9-12
