AForceOne
Flight distance : 5339846 ft
devilsBastard Posted at 2018-9-14 13:19
You are using Premiere Pro, I suppose? Yep, it is a feature that you can only use a stabilizer effect on nested sequences. This effect crops the size a bit, that's one reason why I set the size to 1080p.
Thanks. I will try it again. Since the phones are 4:3 and not 16:9, it would not stabilize regardless the number of times I tried to nest it. Will try it again or find away to make a photo work in 16:9, nested, and stabilized. |
