iPad Mini 4 doesn't work with M2P
1639 13 2018-9-14
Eric13
Flight distance : 15791362 ft
Latest Go4 version, latest firmware on AC.
Any idea how to solve this?
This is what I get when connecting the iPad:
2018-9-14
MavicFit91
Flight distance : 573225 ft
Thats weird. My Ipad Mini 4 works fine. What IOS are you using and what DJI go 4 did you download?
2018-9-14
MavicFit91
2018-9-14
DJI Gamora
Hi, thanks for reaching DJI Forum. We do apologize for the troubles you had making this up and running. May I ask for the iOs version of your iPad Mini 4? Thank you.
2018-9-14
Eric13
DJI Gamora Posted at 2018-9-14 04:53
It is 11.4.1
2018-9-14
DJI Gamora
Hi, I assumed you already uninstalled and reinstalled the app? Do you have any device that we can try to download the DJI Go 4 App?
2018-9-14
Eric13
DJI Gamora Posted at 2018-9-14 05:18
Uninstall and re-install did the trick.
Thanks!
2018-9-14
DJI Gamora
Eric13 Posted at 2018-9-14 06:14
Thanks!
Hi, no worries. Have a safe flight always.
2018-9-14
A CW
Flight distance : 15283773 ft
Mini 4 works fine for me
2018-9-14
The_Death_Angel
Flight distance : 134062 ft
My iPad mini 4 doesn’t work using th USB cable from the bottom of the RC however using the side connection it works but that side cable is too short. Anyone else have this problem?
2018-11-21
Adam9997
Flight distance : 2938389 ft
The_Death_Angel Posted at 11-21 00:53
Check or replace your cable. I have no issues using the bottom or the RC connector
2018-11-21
msinger
Flight distance : 236647 ft
Did you remove the cable on the side before attempting to connect your iPad Mini to the bottom USB port? The bottom USB port will not work if a cable is inserted in the side.
2018-11-21
FatherXmas
Flight distance : 4058619 ft
msinger Posted at 11-21 07:36
And nothing needs to be connected to the cable. Seems weird that just a cable with nothing connected would cause an issue, but it does.
2018-11-21
The_Death_Angel
No i think it was still plugged in. I will give this a go. Thank you.
2018-11-21
