theothernt
Flight distance : 436171 ft
So, there are two parts to this...
1. Why does the Mavic Pro only give a 24p option for at "full 4K"... probably a limitation of the image/video processing at the time, it's really hard to know unless DJI state why.
2. Newer drones supporting more frame rate options or higher bitrates is easier to explain, the chips they use are faster and more power efficient.
In the case of the Mavic 2 Pro, it's taking more information from a bigger sensor (20mpix, 10bit) and processing that into more complex formats (H.265) at higher bitrates (100mbits).
But a better comparison is the Mavic Air, which appears to use the same sensor as the Mavic Pro but is backed by a newer, more powerful image/video processing which give better results.
