updating new m2pro battery
619 7 2018-9-14
Dan110645
Flight distance : 1315436 ft
Today I received an additional mavic 2 pro battery That I ordered from DJI.  I fully charged the battery and put it in the m2p turned on the remote and the m2p and opened the dji go 4 app on my Iphone 7 plus.  I got the message inconsistant firmware found and i clicked update now.  It started the update and quickly went to 30 % complete the it seems to have got stuck.  It has been at 30 % for over an hour and a half.  I turned off the m2p and the controller and tried to update it using dji assistant 2.  When connected to my macbook pro it said I had the latest firmware installed.  I did a refresh on the firmware and it went through to completion.  I than restarted the controller, the m2p and the dji go 4 app and it showed that it was still updating and stuck at 30% and wont let me do anything.  Ihave tried powering off m2p and controller several times and it still stays stuck at 30 %.  Does any have any ideas to help me.  I would greatly appreciate it
2018-9-14
jimmylee
Flight distance : 367352 ft
Delete the go 4 app and reinstall
2018-9-14
A CW
Flight distance : 13864580 ft
Yep - reinstall the app and try again. Alternatively, download the FW in Assistant 2 on the drone - place the battery in the drone then upgrade the FW - the battery FW will update with the drone.
2018-9-15
Wachtberger
Flight distance : 261509 ft
It will work smoothly with DJI Assistant.
2018-9-15
DJI Paladin
Flight distance : 318 ft
Our apologies for the inconvenience. Kindly restore the settings to factory defaults and upgrade the firmware using DJI assistant 2. Please turn off your firewall and antivirus software and reinstall the software. You can download the DJI Assistant 2 using this link: (https://www.dji.com/mavic-2/info#downloads) and follow the video tutorial below.
2018-9-15
Dan110645
Thanks to all for your help, I will try again using Assistant 2.  and  I will also delete and reinstall DJI Go 4
2018-9-15
DJI Paladin
Dan110645 Posted at 2018-9-15 03:53
Make sure to back up your files and sync your flight records first before you uninstall the APP. Please keep us posted.
2018-9-15
DJI Paladin
2018-9-15
