Remote control
TomWolves
Flight distance : 110577 ft
hey people, I did a search but came up with 0 , My question is; How do you know when the remote control on the Phantom 3 is fully charged? do the lights stop blinking? Thank you for your help.
2015-5-30
marco0002.telen
Flight distance : 2079551 ft
Belgium
yeah they wil stop blinking when it is finished
2015-5-30
TomWolves
Thanks marco0002, it seems to be taking awhile. I appreciate your reply.
2015-5-30
Oliver
TomWolves Posted at 2015-5-31 03:07
Charging my controller took even longer than my battery the first time I chraged them!
2015-5-30
Arvy55
It takes me 2-3 hours to charge my battery, and i think that is normal, as the RC battery is way larger than the aircraft battery
2015-5-30
salota8550 This user has been deleted
2015-5-30
gregg1r
Arvy55 Posted at 2015-5-31 05:05
It takes me 2-3 hours to charge my battery, and i think that is normal, as the RC battery is way lar ...
Not quite. The battery in the transmitter is make up of two 3.7 volt, 3000 mAh batteries wired in series.
The battery in the remote is only a 7.4 volt, 6000mAh batter.
The Phantom uses a 15.2 volt, 4480mAH rated battery. The batteries used in the Phantom are rated for a higher discharge rate of 35 amps.
The charger provides two different voltages. When it's charging the remote, it charges at .75 amps, 8.4 volts. When charging the Phantom's battery it charges at almost 5 amps.
Run the Phantom for a couple of minutes and immediately pull the battery. It will be too hot to hold due to the high amperage being pulled.
2015-5-30
