Istrian
Flight distance : 2051860 ft
Croatia
"Mavic 2 Pro uses a different processor than P4P and has two 4K modes, as stated on the product page, which are FOV mode and HQ mode. FOV mode has a wider view but less details than HQ mode. FOV mode's image processing requires raw subsampling, which scales 5.5K raw into 4K raw before feeding it to the image processing pipeline. Raw subsampling is different from line skipping; it uses the full area (of the 16:9 portion) of the image sensor so the signal-noise-ratio is much better than line skipping. Raw subsampling is also different from pixel binning. It is an optimized filtering & sampling process which is much more advanced than the
simple average mechanism of pixel binning. Raw subsampling causes some loss in the finest details. However, this is not as visible in real scenes (like aerial
filming) as it is on charts. DJI looked into many solutions for implementing FOV and found that the current FOV mode is the best compromise for the Mavic 2 hardware. Please remember the Mavic 2 is an extremely complex and compact piece of hardware. The current solution represents the best possible way to enable filming using the full 1” sensor wide angle area FOV on the Mavic 2 hardware."
Customer support answer I found in video comments |
