Mavic 2 Pro ND filter Set
2189 17 2018-9-20
Schmooit
Flight distance : 1336581 ft
Hi All
Is it worth getting these or is it just better to adjust in post? Im considering them, shame I cant use my 20% Select discount on them (not sure what I get out of Select if im honest!)
Ive seen others on Amazon and Ebay which are marginally 20% cheaper so just wondered what peoples thoughts are, I have them on the MPP and Air just not sure if its better to have them or not (the only donwside I can see is knwowing which one to use and having them with you all the time and maybe spoiling a take by selecting the wrong one)
Interested in your thoughts
Cheers
2018-9-20
Maveric
Flight distance : 377244 ft
You can't adjust what ND filters do in post so if you want the benefit of them then they are worth getting.
2018-9-20
Schmooit
Maveric Posted at 2018-9-20 06:48
Could this not be color graded in say like Davinci Resolve that's what I was thinking as there are luts that can mimic the effects of an ND filter, I use them on my DSLR  for bulb photo's but just wondered if spending another £100 on them is worth it or is it worth waiting a bit for Amazon versions seeing as the select discounts are not available  on these
2018-9-20
Maveric
Schmooit Posted at 2018-9-20 08:07
Of course you can change the colour/brightness/contrast levels in post but that's not why you would use an ND filter. Ideally an ND filter should not change the colour of the light going through it at all.
As you already do with your DSLR, you're using it to control the amount of light hitting the sensor so that you have the ability to lower the shutter speed (for motion blur) or widen the aperture (for DoF / image quality) and both of those things are tricky to add in post, especially for video.
2018-9-20
dronist
You don't need to because you can control the A, S manually now!
2018-9-20
Maveric
dronist Posted at 2018-9-20 08:32
If you want to use 100 ISO, record 24p using a 1/50 shutter and stay under F5.6 to avoid lens diffraction, then you probably do need to.
2018-9-20
El Diablo
2018-9-20
SirPasta117
Flight distance : 400787 ft
Maveric Posted at 2018-9-20 08:40
Exactly. Being able to lower the Aperture can help in a  pinch to reduce the amount of light coming in while keep ISO low and 180 degree shutter, but it can cause issues. ND filters are still the way to go to help get the best shots.
2018-9-20
Schmooit
Ok Cool looks like Ill get some again then I mainly shoot video so the motion blur is not something ive even considered on the drone I assume these new ones for the pro just clip on and off  easily? shame we cant use the 20% discount from select on them though otherwise is a no brainer
2018-9-20
Maveric
Schmooit Posted at 2018-9-20 10:26
Ok Cool looks like Ill get some again then I mainly shoot video so the motion blur is not something ive even considered on the drone I assume these new ones for the pro just clip on and off  easily? shame we can use the 20% discount from select on them though otherwise is a no brainer
Cool. Have a look at some of the videos on YouTube about the 180 degree shutter rule. It's pretty interesting.
No idea on the filters for the M2P - I'm still waiting for mine to arrive!
2018-9-20
DJI Gamora
Hi, thanks for reaching us here in DJI Forum. We do apologize for the troubles you had. Kindly check this Forum thread provided below. This may help you with the Mavic 2 Pro ND filter set. Thank you.
https://forum.dji.com/thread-166941-1-1.html
2018-9-24
CineView Media
Flight distance : 5365522 ft
Norway
For video you def do.
2018-9-24
Schmooit
HI Guys Just an update I ordered a set of the DJI Filters in the end  and they are really well made I bought them from Wex Photo and video in the end as they were cheaper than DJI! (they are £79.00 with free shipping (I had to wait for DJI to get stock so I thought I might as well wait for Wex to get them in too!)
They are the same price as DJI were charging when they released the Mavic 2 so but wouldnt allow us to back order so they then put the price up to £99.00 and would not allow select customers to use their 20% off accessories, otherwise I would have bought them! Good work there DJI
2018-10-15
hallmark007
Flight distance : 9812789 ft
Schmooit Posted at 2018-10-15 12:04
I have just received a new set of SkyReat both polarized and ND to review, they are completely New design with circular polarized filters, from what I’ve seen so far they are exceptional quality , but am jousting testing them at the moment and will post my honest opinion in a couple of days. I can say that there pricing is extremely competitive.
2018-10-15
MrTitan
I did exactly the same as you. The DJI ones have proven to be excellent so far. Well designed, easy to install, excellent carry case. Initially I thought the filters were quite expensive, but they were actually well worth the price at £79.
2018-10-16
El Diablo
2018-10-16
A CW
Flight distance : 13838848 ft
I would get them if your record video a lot and include a degree of motion in your footage.
2018-10-16
Schmooit
I got them inn the end I have always had them on the other drones Ive had I just wondered with the new HB super-duper processing and colour do dahs that I might not need them, Ive bought them know as I think most of the what I take is video, the only bugger is knowing which one is best to use on any given day which out trying them first, I normally use ND4 as a general filter during normal overcast days, then when the sun comes out to play a 16 during the day unless its full on summers or winter sun, 32 comes out when its full on sun, 8 is early evening and then back to 4 for a sunset, night generally off depending on where im filming maybe the 4.
Ive read lots of different posts on using filters for the DSLR and find they server pretty well, and with a little more time swapping them while out is no biggy so if its scenery that isn't going anywhere I normally set myself a couple of routes and then then swap over the filters to get several takes!
I guy did offer me a free trial of the SkyReat ones but I had to buy them first and then get a refund from him so wasnt sure if it was a worth it and then found the Wex ones for £79 which were gen DJI so it was a no brainer!
2018-10-16
