astrofly
Flight distance : 554301 ft
DJI Gamora Posted at 2018-9-21 03:16
Hi, thanks for reaching DJI Forum. We do apologize for the troubles you had. The Lenovo tablet you used to run the app is not compatible to run the app. I will be uploading some of the supported devices below. I'd like to ask as well if you format the SD card when you activated the aircraft. We're here to help you. Thank you.
[view_image]
If the Lenovo tablet is not compatible because it has worked well for months? The sd card records well. It seems that the radio signal between the drone and the radio control is weak or delayed. Thanks for the models shown. |
