Are there any other telematic data available from flights other than the obvious distance, speed, height and duration of flight? If "yes" then where can it be found?
You can find additional data in the TXT flight log on your mobile device. The TXT flight log can be uploaded and view online here. The attached CSV files will contain the additional details you're seeking.
msinger Posted at 2018-9-21 11:14
HendrikJB Posted at 2018-9-21 11:53
Thank you for the information. Where does one do the sync`ing as sync now works with DJI 4 GO to the DJI Forum.
There is an app in the app- or playstore called HD Sync. It syncs the go4 data from your device to airdata.com. If you use lytchi you can generate a token within the airdata site and import it into lytchi for automatic synchronisation. Works really nice.
