Mavic Pro - Mavic 2 Goggles
662 5 2018-9-22
Z-Zoom
Flight distance : 27438 ft
I want to buy a set of DJI goggles. I have the Mavic Pro and Mavic 2. I want a set that I can use for both and get the best performance. I believe that the new (black) set can also be used for other drones, not DJI. But I want to buy the set that I can use for both Mavics and get the best results! Black or White.
2018-9-22
Dirty Bird
Flight distance : 11500532 ft
Answered in your other thread...
2018-9-22
DJI Stephen
Super Moderator
Hi there, thank you for reaching out. Regarding your concern yes you can use both DJI Goggles(white) and the Racing Edition to Both Mavic series.
2018-9-22
Mavical
Flight distance : 2206696 ft
DJI Stephen Posted at 2018-9-22 09:55
Looking for some thoughts on this from you Stephen if you have it…
I am running the latest firmware on my Mavic 2 Pro & RE Goggles, they connect fine, however after flying just 200 feet away from the Goggles the connection drops completely.
Can you please either offer a step by step set of instructions/suggestions on how to fix it, or let us know if this is indeed a known issue that will be addressed down the road with a firmware update by DJI.
Thanks
2018-9-22
lt_photographer
Flight distance : 46083 ft
Mavical Posted at 2018-9-22 12:47
i had that problem too but i was unlucky because my mavic 2 crashed
2018-9-23
Mavical
Stephen,
I am running the very latest application versions and device's firmware:
Mavic 2 Pro
- Application version: DJI Assistant 2 For Mavic v2.0.2 / Firmware: V01.00.0000
DJI Goggles RE
- DJI Assistant 2 v1.2.4 / Firmware: V01.00.0600
To recap the issue that many of us on this forum are experiencing, the Goggles RE edition disconnect from the Mavic 2 Pro after barley a few hundred feet away. I have refreshed at least 3 times and still have the same poor distance results.
Can you please officially tell us if this is a known issue and that DJI is working in it… or if we should return our Goggles for replacements? Please advise.
Thank you.
2018-9-26
