Tahoe_Ed
Flight distance : 2605 ft
Sorry, I did not have enough information on what you were trying to do. Right now in order to use the P2 Tx the lead to the LB ground unit needs to be reversed. I don't know how you can do that with the Y cable. I use the P2 Tx on my P2Z3 with Lightbridge and just plug the red end into the ground unit and the black end into the Tx. It works but I am not sure how you can do the same with the Y. Sorry.
One solution would be to run the RC with the Futaba through the Lightbridge and use a P2 controller on 5.8gHz with a Rx to control the camera.
