Porktree
Flight distance : 1118323 ft
Yesterday I got my fly more pack for my M2P. I charged the batteries, then updated them. All went as expected. I flew with the original battery this morning, then this afternoon took the M2P out to a nearby lake to fly around. Using one flymore batteries, at about 50%, I lost video, and got the message there was a "Version mismatch, Update All Modules". I brought the drone home, and then went home. I tried checking the firmware version and it couldn't get it (ios app, holding down the 3 lines top right for 3-4 seconds - Current Version Unknown). So I plugged into my Surface and ran the DJI Assistant for Mavic 2.0, this tried downloading firmware 1.00.0000 (I updated this brand new drone 3 days ago). It failed on the dl at 1%.
I put the original battery back in, and everything worked once, then the same message, so evidently not a battery issue. I'm currently trying to update with the DJI Assistant right now. It just errored out, and needs javascript to upload the log, seriuosly wtf javascript? It made it to 3% that time. I'm assuming that DJI is having a network issue (I'm testing my network and I have 50 up and 50 down so its not on my end).
I noticed also, that the Gimbal Status is "Gimbal Disconnected" and Interal Storage Remaining is "Internal Storage not found" which seems wrong. All this stuff is only 3 days old, and I am pretty annoyed.
Edit: Ok, it was the memory stick, curse you Kingston! All signs normal. I'm leaving this here so that my failure to troubleshoot can stand as a beacon for others. Damn.
