I have set the RTH altitude on my drone to 80M. In case I will be flying at 90m and the RTH kicks in, will the altitude remain at 90m or the MA will go down to 80m?
I am asking because yesterday I was flying the drone above a cliff 100 high, and was concerned what would happen if RTH kicked in.
Thats correct if your current flying altitude is above the set rth altitude it will hold its current altitude unless it encounters an obstical in which case the drone will try and gain altitude to avoid the object.
If your current altitude is below that set by rth then when rth is initiated the drone will raise to the set altitude then start on its rth path.
