Kenma
Flight distance : 338537 ft
Singapore
Hi guys, I recently updated my Mavic Pro to the latest firmware 1.0.5.0500, it was a jump from .0300. Prior to update it works perfectly fine. I just update it because I feel like it was already outdated. So I updated the drone using dji assistant v2. It went successful.
After completing the process and booting up, the camera started to have some issues in a sense that the DJI GO App just in black. The selection of Auto, and Manual are not highlighted. I mean if you tap them it will do nothing. Trying to reset the camera settings will result to "Resetting Failed". The controller was also not able to tilt the camera, even on how long you pitch the camera dial it will not react for some reason. Take note that the camera somehow work, I mean it can still see things because I have tried to recalibrate the camera via assistant and it was able to calibrate it properly with the black and white dots guide on the screen. I can see the camera preview on the screen too. But on the App its nothing and was not able to control it, I can't record nor shoot photos.
Another thing is that the SD card started to be unrecognized. Even if I swicth a new and old sd card the drone will not detect the new card for some reason. Even tried to reformat the card but it says it has no card but its there I just inserted a new one. But why this is happening after the upgrade?
Also I can start the motor, I can fly it just no display, I can't record videos and shoot photos. I can still land and off it properly. The camera startup also being initiated everytime I power it on. I just noticed something new tho, that when I turn it off, it will stay on for like 2-3seconds with the top battery led blinking state and then it shuts off.
I haven't fly this drone much after a couple of months but like I said the .0300 version was just working fine. But since I updated the mobile app, it says that I need to update the aircraft firmware as well and then I did what was instructed and then it went well then end up having issues. Hows that? Should I downgrade? Is it possible? Is it safe? Any help would be greatly appreciated.
