My new Mavic 2 Pro is stuck on Poor radio channel quality
123Next >
11929 99 2018-9-24
shredder777
Flight distance : 114928 ft
Question : On my new Mavic 2 Pro, The "Radio Channel Quality" has been on poor for the last few days. I flew in multiple locations since saturday and its been poor.
I did a test and I fired up my old mavic and it says good. in same location and everything. Any suggestions, should I call dji or go to forums? Thank you for the tips.
2018-9-24
DJI Tony
Hi, Sorry for the troubles that it caused. I would like to ask if you manage to update the firmware of this RC? Could please try to re-link the RC to AC to see if the issue would persist? Kindly keep us posted on the latest progress.
2018-9-24
shredder777
DJI Tony Posted at 2018-9-24 16:26
Hello Tony, I did a relink last night and it is the same today.  I just tried my phone instead of the ipad and its the same.  I did try to update the firmware on sat a few times and when I tried that, I only had success by plugging the AC to the computer and assistant worked but, my ipad was stuck on saying "firmware downloaded" . so I tried again via controller/ipad and it updated.  I am thinking it got messed up from the firmware.  I am not 100% sure though.  can I reset the AC and controller?
2018-9-24
tgflyforfun
hi. I have been having the same problem. I am using an ipad 4. It seems to be due to wifi interference between the ipad and the rc. Turn wifi off on your ipad/ tablet and see if that helps.
2018-9-24
Squashpile
Flight distance : 214019 ft
Switch from dual mode to 2.4 and wait a minute. Should resolve it. I think there is a switching issue on RC power on or something.
2018-9-24
shredder777
tgflyforfun Posted at 2018-9-24 17:24
I tried that and its the same issue.
2018-9-24
shredder777
Squashpile Posted at 2018-9-24 17:28
I tried that as well..  so weird.
2018-9-24
tgflyforfun
shredder777 Posted at 2018-9-24 18:27
After turning off wifi, restart your rc. Seems to fix it every time for me. Also, as another member mentioned, I did not have this problem until I did the software upgrade to make the goggles compatible.
2018-9-24
shredder777
I will try the switching off wifi and turning off RC method.  Thank you!
2018-9-24
Raiderfan
Flight distance : 810869 ft
I have been having the same issue,  I have tried tried to Switch from dual mode to 2.4 /switching off wifi and turning off RC method with the same results.  This is only happening with my mavic 2 and not with my mavic air, mavic pro, inspire or phantom 4 pro.  I called DJI today talked to customer service after 30 min of trouble shooting over the phone DJI will be sending me an RMA to return the mavic 2.  I will be sending back tomorrow.
2018-9-24
Zatx
Flight distance : 158166 ft
Mine has never shown anything other than POOR for radio channel quality, yet it has never affected my flights and some of them have been over two miles away from the RC. I'm not entirely convinced this description is functioning as I've never received a warning when two miles out.
2018-9-25
shredder777
Zatx Posted at 2018-9-25 11:23
I see.    I should be ok without issues since I dont do long flight right?  I just want peace of mind as I fly and work on footage...  I hope they fix this soon.
2018-9-26
shredder777
Hi Tony, I been trying to fix this for a few days and not successful.  Should I take it to my local dji store which is in Costa Mesa Ca?
2018-9-26
DJI Tony
shredder777 Posted at 2018-9-26 07:50
Hi, We terribly apologize for the late response. Please provide me a screenshot of the firmware version of your unit and app version. You can locate this information using the DJI GO 4 app and look for "About" section. Thank you for the support.
2018-9-26
shredder777
DJI Tony Posted at 2018-9-26 08:41
its ok.  I hope to get this figured out.
2018-9-26
DJI Tony
shredder777 Posted at 2018-9-26 11:09
its ok.  I hope to get this figured out.[view_image]
I would recommend connecting your RC to your computer and using DJI Assistant 2. Once you've connected the RC, please refresh the firmware and try to re-linking the RC again to aircraft. Thank you for the support. Please see the link below.
https://www.dji.com/mavic-2/info#downloads
2018-9-26
shredder777
Hello Tony, I found out something.  I went to the Image Transmission settings in the app and when its in DUAL mode I have the POOR reading. but, when I switch to custom and switch to 2.4 ghz (-104.4dbm) I get GOOD in (Radio Channel Quality).........Now, it went back to POOR when I turn it off then on.  I did the process again and went back to custom and I got GOOD again in 2.4.
2018-9-26
shredder777
DJI Tony Posted at 2018-9-26 12:13
I will do this now.  just noticed a update on assisitant.  I was using v1 not 2.  I will download and try
2018-9-26
DJI Tony
shredder777 Posted at 2018-9-26 12:44
Hi, Please keep us posted on the latest progress. Hope everything will go well.
2018-9-26
shredder777
DJI Tony Posted at 2018-9-26 12:51
Ok, I updated. same issue.  (POOR) . I went ahead and switched to 2.4ghz and it is on GOOD.  seems like there is a issue with 5.8ghz
2018-9-26
shredder777
2018-9-26
fansa7deb17f
Flight distance : 519708 ft
I just got my Mavic 2 Pro and am having the same issue. Could it be the Firmware. I have the same as shredder777
2018-9-27
Squashpile
Yeah.. just like I said above and many times on here. The behavior is the same. Something is wrong.
2018-9-27
shredder777
I am sure they are working on it.  I found early footage since I have had the drone it is on POOR transmission the whole time and I filmed a lot of footage before I noticed.  I just hope it gets worked out before anything else in the next firmware update.  Keep us posted Tony and dji.
2018-9-27
shredder777
Hello Tony, I was just checking in to see if the engineers figured out a solution.  cheers!
2018-9-29
DJI Tony
shredder777 Posted at 2018-9-29 23:06
Hi, I was able to clarify this situation. I would recommend do the manual re-linking process for you to reconnect the AC to RC. Please check if the issue would persist on 5.8 GHz, however, you can change the location if this error message is caused by environment as well. Kindly let us know if it's still doing the same thing.
2018-10-1
Raiderfan
I have been having the same issue.....I have tried everything mentioned above.  I really dont want to send back for service if not needed.
2018-10-1
Raiderfan
shredder777 Posted at 2018-9-26 13:06
Shredder777 check the radio channel quality status again........ it always switches back to POOR  You can also switch back and forth from dual mode to get a GOOD signal but then eventually it always goes back to poor.   The mavic 2 zoom is going in for service I have tried everything, now lets see what DJI can do for me. I will keep everyone posted.......
2018-10-1
Raiderfan
I thought I was the only one having this issue thank you for posting your findings.  DJI we have a problem please help
2018-10-1
waxings
Im having the same issue but mine is a replacement that was sent to me by DJI on a repair order. Very Frustrating!
2018-10-1
Raiderfan
waxings Posted at 2018-10-1 12:55
Did you send in for service because of the poor radio channel quality ?..........then they sent back a replacement with the same issue?
2018-10-1
waxings
Raiderfan Posted at 2018-10-1 13:06
No It was user error. I dropped it and it messed up one of the sensors. They did not repair it, they sent me a replacement and now Im having this issue.
2018-10-1
Raiderfan
waxings Posted at 2018-10-1 13:10
Thank You,  This leads me to think it may be resolved in the next firmware update.  I was going to send my in today for service but now I will wait to see if DJI will response back to this thread.
2018-10-1
shredder777
DJI Tony Posted at 2018-10-1 12:08
Greetings Tony,  Its the samething still.  I have flown it and it is in the back of my mind "Poor" lol . so, I am skeptical to be normal with it until I can trust it 100% .  I hope the next firmware fixes it.  It seems I am not the only one.
Thank you for keeping us informed...
Cheers!
2018-10-2
shredder777
Raiderfan Posted at 2018-10-1 12:25
Cool Raiderfan, please keep us informed.  I wish I never seen the error (POOR) it just bothers me while flying.lol . lets cross our fingers they fix it next.
2018-10-2
DJI Tony
shredder777 Posted at 2018-10-2 23:44
Hi, Thanks for your response. Your scenario was handled by our engineers. Anyway, the poor signal will persist tho' your flying in a short distance of 5.8 GHz, right?
2018-10-3
Squashpile
Mine will show poor when using dual on 5.8, but the signal str graph is all green and the line is at the bottom. It seems to default to 5.8 in this location in Dual mode. Not sure about everyone else.
I can see why it would pick 5.8 in dual because the sig/interferece meter show nothing. It looks great on the screen, but RC will disconnect quickly even a few feet away. Moving to 2.4 seems to fix it for me even though the signal str and interference on the meter is much higher. It will not resolve itself by changing the freq automatically. It will be stuck until you manually change it to 2.4 and then it will frequency hop.
The line on 5.8 when showing poor/interference will be all the way at the bottom of the screen. I think there is a problem on power on with freq switching. It is weird because there is no 5.8 ghz anything around me that I can tell. The channels/freq look totally clean. I have never been able to use Dual mode. I still have no confidence to fly more than 100 feet or so.
2018-10-3
shredder777
DJI Tony Posted at 2018-10-3 09:16
cool! great news.  Yeap, its in 5.8.  It seems to be within the entire flight from close range (Takeoff) to flying normal flight (over 300ft) .
2018-10-3
shredder777
Squashpile Posted at 2018-10-3 09:57
I can see why it would pick 5.8 in dual beause the sig/interferece meter show nothing. It looks great on the screen, but RC will disconnect quickly even a few feet away. Moving to 2.4 seems to fix it for me even though the signal str and interference on the meter is much higher. It will not resolve itself by changing the freq automatically. It will be stuck until you manually change it to 2.4 and then it will frequency hop.
I agree with you Squashpile.  Tony, Everything Squashpile said is exactly what I am going through.  When I switch to 2.4, it says GOOD.  (I havent flown it like that yet) . I been really cautious just incase.
2018-10-3
shredder777
Hope I am not confusing you guys..lol.   There is something wrong with "Dual".  Thank you guys.
2018-10-3
123Next >
