Inspire 2 Landing gear
1927 14 2018-9-25
Bjarne E. Nielsen
Denmark
The last update makes amber in it. The automation, as far as the landing gear is concerned, does not work properly, so at the moment, I use to turn the landing gear down. Unfortunately, Inspire 2 can not land without any problems with the camera, but it does not work when I turn on Inspire 2, so I have to hold the front end slightly so that the camera can turn its normal rounds.
Do you have the same problem? What can you do about it?
2018-9-25
Matthew Dobrski
Flight distance : 1831050 ft
Unfortunately the translation didn't went smoothly and I have problems understanding what is the nature of issues. Perhaps other forum members will get the message better ...
2018-9-25
Nicksons
Flight distance : 2668717 ft
Argentina
What is the issue?
2018-9-25
Denis SF
Flight distance : 1783087 ft
Hello, Which camera do you have? X7?
2018-9-25
DJI Wanda
Hi. Thank you for reaching DJI Forum. I'm sorry I'm confused. Can you please elaborate more the issue or is it possible to provide a sample footage showing the problem? You may send it through youtube or Dropbox and provide us the link.
2018-9-26
Bjarne E. Nielsen
Denmark
The landing gear does not go far enough down, when landing.
2018-9-26
Bjarne E. Nielsen
Denmark
DJI Wanda Posted at 2018-9-26 00:12
The landing gear does not go far enough down, see the photos
2018-9-26
Bjarne E. Nielsen
Denmark
Denis SF Posted at 2018-9-25 23:59
I'm using the X5S
2018-9-26
DJI Wanda
Bjarne E. Nielsen Posted at 2018-9-26 01:00
Thank you for the response. Please spin the slotted screwdriver which locates underneath the drone with a screwdriver to check if the steer got stuck, please let us know if this helps.
2018-9-26
Bjarne E. Nielsen
Denmark
DJI Wanda Posted at 2018-9-26 01:36
I could not find that screw, but I took the camera off the drone, pressed the start button 5 times and the drones landing set went further down. So now it works.
2018-9-26
Rodger8
Flight distance : 20145135 ft
Try cycling the gear manually, that is, using the worm gear through the round opening on the bottom of your I2. With the worm Gear fully exposed put some dry lube on the threads. I use Frog Lube Paste. Cycle the gear all the way up and down a few times with the lube on it. Be sure to use a quality flat head screw driver that fits perfectly. so you do not damage the slot at the end of the worm gear. I use a Whia flat head driver. Check to see if the camera has clearance under it when you have cycled the gear all the way down manually.
2018-9-26
Bjarne E. Nielsen
Denmark
Rodger8 Posted at 2018-9-26 03:54
I have done what you wrote
2018-9-26
Rodger8
Did it work out? If you cycle the worm gear all the way down, dodo gain any height?
2018-9-26
Nicksons
Argentina
There is hole underneath, and you need to get a small flat screwdriver, when you turn the worm gear moves, try reaching endpoints, it’s has to be smooth, check it’s perfectly clean from dust, and with the clear synthetic grease covering the whole visible part of the worm, if that’s not the problem, it could be a middle frame issue or servo motor damage.
2018-9-26
Nicksons
Argentina
[view_image]
And please my friend lift that bird, it hurts watching that beautiful camera touching ground!!! Hope to see you back on air soon!
2018-9-26
