DJI Susan
fansbe57bb1b Posted at 2018-9-26 12:00
THE WIND WAS NOT STRONG. ONLINE THE SPARK IS PROMOTED AS BEING ABLE TO FLY IN 30MPH Winds. I was flying in winds less than 10mph. I went to look for the drone as well, my family and I did a thorough grid analysis and it was still unable to be found. We all work in Search and Rescue and couldn't find it. DJI should be providing me with a large discount because I wasn't able to find it at the corrdinates they provided. IF I HAD FOUND IT AT THOSE COORDINATES THERE WOULD BE NO ISSUE HERE.
My case number was 1191494-Q2R9J0.
Thanks for the info, Eva. The case number you offered is not matched with your description, we managed to get the correct case number CAS-1911494-Q2R9J0. And upon further checking, this has been handled already by our Managers previously and they have made this clear, please kindly find the data analysis result:
1. The aircraft worked in GPS mode in the flight.
2. At t=00:59, h=22m, d=104m, the aircraft tilted 8.6° pitch and -14.2° roll to resist the strong wind without any pilot input, please kindly refer to the first screenshot.
3. At t=04:26, h=-153m, d=628m, the aircraft triggered the RC LOST RTH, the pilot set the return height 30 m, the aircraft rose and pushed by the wind, it cannot RTH normally.
4. At t=07:47, h=-221 m, d=900 m, the battery was 10%, it triggered the critical low battery auto-landing,the aircraft started to descend,and the flight record interrupted at t=07:50, h=-220 m, d=897 m.
Conclusion: The pilot did not pay attention to the flight environment. The higher the altitude, the stronger the wind. For this kind of situation, we're sorry that we can not offer you the warranty service. If this doesn't match your situation, please kindly point it out, we'd like to double check with our engineers. Thanks for your understanding. |
