Nebuchadnezzar
Flight distance : 3440476 ft
Please check DJI Flight Log Viewer : https://www.phantomhelp.com/logviewer/Upload/
Locating Your Flight Logs Follow these instructions to locate the flight logs on your mobile device:
- For Apple mobile devices, follow these instructions to retrieve your DJI GO TXT flight logs from iTunes. After retrieving your flight logs, click the Browse... button above to select a flight log and upload it.
- Note: If you're using Litchi, you'll want to select Litchi in the listed apps and retrieve the flight logs from the flightlogs folder.
For Android mobile devices, connect your mobile device to a computer via a USB cable and go to DJI\dji.pilot\FlightRecord (for DJI GO 3) or DJI/dji.go.v4/FlightRecord (for DJI GO 4).
- Note: If you're using Litchi, you'll find the flight logs in the LitchiApp/flightlogs folder.
- Note: If the log files are not visible or you're not able to find a specific log file that should be there, then install and run SD Refresh or restart your mobile device.
- For the Phantom 4 Adv/Pro + remote controller, connect your remote controller to a computer via a USB cable and go to DJI\dji.pilot.pad\FlightRecord. If needed, you can find detailed instructions here.
Getting Help With Your Flight Logs If you need help, please create a new topic in the DJI Drone Help forum. If you have questions about a specific flight log, please upload it above and include a link in your forum topic to the page that opens after uploading your flight log. It would also be helpful if you include as much information about your flight as you can remember.
